Is my shifter bushing missing?
P
PHulst
Bronze
Brought the lever control to a machinist friend today. The base of the hole (original diameter) was 0.695 inches, similar to the 0.7 that Duane noted. I measured the egged-out opening at 0.8, but inside was worn so much we milled out to approx 0.9 inches in order to have enough native material to allow a new sleeve to properly align.
An original bushing on the end of my current shifter measures at 0.680, and a replacement bushing is even smaller. The plan is to machine a sleeve to 0.685 giving it 0.005 clearance and see how that works. Odds are that will give the shifter enough clearance for the current original bushing or any aftermarket replacement.
I will update this once I get the parts back later this week. We didn't have time today to make the sleeve, so he will do that in the next few days.
Always good to see a proper repair on an original part. The brass shifting forks eventually wear down, but can be brazed up and milled down as good as new; presumably, you can do that an unlimited number of times. For contrast, many (most?) modern transmissions use plastic on shifting fork contacts, and when they wear down--or break--they are NFG.
P
PHulst
Bronze
Today I had a chance to pick up my repaired control lever for the transmission. I've attached a photo.
You can see by the thickness of the sleeve how much we had to mill out in order to reach enough original metal to support the new sleeve both on top and bottom. The sleeve was honed out just enough to give the bushing on my shifter the clearance it needed to work well.
Of note, using an original bushing the size is a bit larger, but the inside where the shifter inserts is worn enough to give it some slop.
Using an almost new bushing which is minimally smaller but not worn inside, there is virtually no slop in the system at all and it is a significant improvement from where I started. If I were designing the control lever, or thinking of another repair, you could likely make the sleeve taller and have it support the bushing even more as you go through the motions of the shifting.
In an event, an original part was saved and my first Austin-Healey repair project is done. I actually finished the fuel tanks sender already, but started the transmission first so it's the first one I undertook.
Thanks to Duane and Richard for the offer of parts. If anyone ever needs this part repaired in the future it's not that difficult for a machine shop to do over the course of a couple of hours.
Patrick
Martinld123
Bronze
On my new 100-6 the previous owner told me he never could get the lower shifter bushing to work correctly whether he tried the brass original or nylon replacement. I removed the transmission tunnel cover yesterday to do some looking, and removed the shifter to have a look.
Shown in the photos are the shifter, a small wire ring laying in there, and a view into the shifter area of the transmission. All parts removed are shown, other than the nuts/washers holding the shifter in place on top.
I can't tell by looking so can anyone tell me from experience if there is still a bushing laying in there? If so, how might it be removed?
Just trying not to break anything.
Thanks for your assistance!
If I understand your problem I might have had the same problem with my BN2 trans. My shifting was very lose in and around neutral and very very hard to tell what gear I was in. I also thought the problem with my shifting was the brass or the nylon insert but instead the centering screw that centers the ball just needed to be turned 90 degrees to steady the shift center point, if that is clear? I had also blamed the problem on cooper insert and also the nylon one I bought but in the end it was just that centering screw that centers the shift ball in the groove had to be turned 90% to make center. Easy fix so I hope that is your problem. Marty
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
S Shifter Bushing Question Austin Healey 2
johnrip Wedge tr7 shifter bushing instalation Triumph 1
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
S 1993 dodge Dakota shifter Other Cars 9
KVH General TR Shifter Stuck Triumph 6
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
B MGB 1977 MGB Battery Box and Shifter knob MG 4
V GT6 Shifter Worn? Triumph 2
dbenichou289 TR2/3/3A Shifter knob jam nut Triumph 2
66healey BJ8 shifter spring install Austin Healey 2
VelodromeRacer BJ8 Shifter reinstall Austin Healey 4
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
Rut Bugeye shifter cover [top hat] Spridgets 6
W General TR Shifter Question Triumph 16
P Shifter Spridgets 3
T Shifter Cupola for Datsun 5 speed Spridgets 19
D TR4/4A shifter anti rattle pin Triumph 2
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
maxwedge5281 center shift transmission shifter Austin Healey 3
S TR2/3/3A this shifter/ ball and cup Triumph 5
M TR2/3/3A Gear Shifter Maintenance?? Triumph 3
6 Shortened shifter? Spridgets 9
P TR2/3/3A TR3 shifter popping out of selector shaft Triumph 10
KVH The Shifter Again--and I'm Stuck Triumph 10
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
KVH My Shifter is Stuck Triumph 10
bugedd Shifter boot Spridgets 18
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
64rocksprite Datsun 5 speed bronze shifter bushings Spridgets 3
P Shifter MG 7
M Spitfire Need '75 to '80 Spitfire overdrive shifter Triumph 2
T TR4/4A my bad- need tr4 shifter photo Triumph 12
Got_All_4 Wedge TR7 rubber 5 spd shifter boot Triumph 6
Rut 5 speed shifter bushings Spridgets 8
S "Buzzy" shifter handle... MG 2
B Datsun transmission shifter levers- Spridgets 16
rlich8 Thread for Shifter Triumph 5
drooartz Floor mats and shifter Spridgets 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
69sprite rubber shifter boot won't stay Spridgets 8
PatGalvin TR2/3/3A TR3 Shifter and Motor Mount Support Ques... Triumph 7
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
J Recovering AH shifter dome with leather cloth Austin Healey 16
M Toyota 5 speed Shifter Austin Healey 2
A sloppy shifter !! somthing must be wrong Triumph 7
A shifter knob with lift on the face ? Triumph 5
