TR2/3/3A Shifter knob jam nut
dbenichou289
Member
I need to install a jam nut to allow the shifter knob to point in the correct direction when installed. I thought the threading on the knob and shifter was a 7/16-32, but it appears it is not. Anyone know what is the correct thread size and pitch? Thanks
GeneW
I believe that 7/16 -32 is correct. Hope that is true, as I've used a 7/16-32 tap/die on several knobs/shift levers.
dbenichou289
dbenichou289
Member
I wanted to circle back around to this as it is indeed 7/16-32. I was having an issue with the end of the threads on the shifter handle itself where the jam nut starts, however the shifter knob did not touch this area with the way it is worn. Once I cleaned up the threads a bit better, everything fit as it should. Hopefully this helps someone in a future search.
B MGB 1977 MGB Battery Box and Shifter knob MG 4
A shifter knob with lift on the face ? Triumph 5
John Moore Shifter Knob Thread Size Spridgets 3
T overdrive switch in shifter knob? Triumph 19
Aldwyn Spitfire OD Switch on Shifter Knob, ala Spitfire? Triumph 12
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
S 1993 dodge Dakota shifter Other Cars 9
KVH General TR Shifter Stuck Triumph 6
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
V GT6 Shifter Worn? Triumph 2
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
66healey BJ8 shifter spring install Austin Healey 2
VelodromeRacer BJ8 Shifter reinstall Austin Healey 4
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
Rut Bugeye shifter cover [top hat] Spridgets 6
W General TR Shifter Question Triumph 16
S Shifter Bushing Question Austin Healey 2
P Shifter Spridgets 3
T Shifter Cupola for Datsun 5 speed Spridgets 19
D TR4/4A shifter anti rattle pin Triumph 2
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
P Is my shifter bushing missing? Austin Healey 25
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
maxwedge5281 center shift transmission shifter Austin Healey 3
S TR2/3/3A this shifter/ ball and cup Triumph 5
M TR2/3/3A Gear Shifter Maintenance?? Triumph 3
6 Shortened shifter? Spridgets 9
P TR2/3/3A TR3 shifter popping out of selector shaft Triumph 10
KVH The Shifter Again--and I'm Stuck Triumph 10
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
KVH My Shifter is Stuck Triumph 10
bugedd Shifter boot Spridgets 18
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
64rocksprite Datsun 5 speed bronze shifter bushings Spridgets 3
P Shifter MG 7
M Spitfire Need '75 to '80 Spitfire overdrive shifter Triumph 2
T TR4/4A my bad- need tr4 shifter photo Triumph 12
Got_All_4 Wedge TR7 rubber 5 spd shifter boot Triumph 6
Rut 5 speed shifter bushings Spridgets 8
S "Buzzy" shifter handle... MG 2
B Datsun transmission shifter levers- Spridgets 16
rlich8 Thread for Shifter Triumph 5
drooartz Floor mats and shifter Spridgets 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
69sprite rubber shifter boot won't stay Spridgets 8
PatGalvin TR2/3/3A TR3 Shifter and Motor Mount Support Ques... Triumph 7
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
J Recovering AH shifter dome with leather cloth Austin Healey 16
