KSchoknecht
Greetings all - - I have a 1966 BJ8 (HBJ8L 33606, built in November 1965) with an anemic horn that larger (that is, all) other cars don't hear. I just bought a pair of Hella Sharp Tone horns from Moss Motors. The diagram that accompanies the horns (attached) shows I should wire the horns as shown in Graphic 2a if the horn switch on the steering wheel is connected to the ground negatively, or as shown in 2b if the horn switch is connected to the ground positively. The icons that appear in the diagram aren't familiar to me.
How do I know whether my horn switch is grounded negatively or positively?
Also, the diagram appears to show a 16-amp in-line fuse between the battery and the relay switch. Don't I already have a fuse for the horn in the fuse box? Do I need to install another 16-amp fuse as shown in the diagram, or will the existing one suffice?
Many thanks in advance,
Kim
Kim
