    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Intake/Exhaust gasket
Healey Nut
So does it go with the metal side to the head or to the manifolds ?
Good question
I followed what was there when I bought the car. Mine was metal to the manifold, not sure if it was right though.
:cheers:
Bob
Well I made it an easier decision . Got a new gasket today and its metal both sides .
Guess it depends on who does the repro gasket as to how its made .
I can't say positively how it goes, but it's a lot easier to scrape fibre gasket remains off the (3) manifolds than it is from the head face__with all the studs in the way.
I still do my work thinking that I might be the next guy that has to take something apart...
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
dklawson 1500 Intake/Exhaust Gasket - Siamese Ports? Triumph 10
N Which way for intake exhaust gasket? Triumph 1
VelodromeRacer Exhaust/intake gasket Spridgets 6
B Intake/Exhaust Manifold Gasket Triumph 3
C Exhaust/Intake gasket sealer? Austin Healey 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
J New tube exhaust and intake manifold Austin Healey 15
J TR2/3/3A leak proofing intake/exhaust manifold Triumph 20
H intake and exhaust question Austin Healey 4
dklawson MGB MGB Intake/Exhaust Needed - [re-posting] MG 7
mgedit TR2/3/3A 56 TR3 Intake and Exhaust Manifolds Triumph 8
doughairfield Intake/exhaust manifold gaskets Triumph 1
bcbug removing exhaust/intake manifold Spridgets 6
R installing Intake Exhaust mainfold Triumph 18
W Replacing Exhaust/Intake gaskets and studs. Triumph 2
2wrench Opinion on intake and exhaust manifold studs Triumph 5
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
Brosky Studs for intake/exhaust manifolds Triumph 2
Brosky Intake and exhaust manifold powder coating Triumph 18
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Intake header crossover passage..... Triumph 4
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
steveg TR6 Fixing the intake manifold Triumph 8
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Michael Oritt Intake manifold question Austin Healey 11
steve00136 MGB Intake manifold alignment MG 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
