Exhaust/intake gasket
VelodromeRacer
I am about to install my intake/new exhaust header and while I have the gasket, I wonder about the gasket.
Do you use any sealant on both sides of the gasket? I was wondering if I should wipe a thin amount of RTV red for high heat on both sides?
Thoughts?
jlaird
No sealer on that. Just make sure the surfaces are clean.
VelodromeRacer
VelodromeRacer
Ok, Getting the idea here...
I am re-installing my race engine after changing to the Taylor Box I bought from Hap. I am in the process of getting a custom exhaust next and wanted to double check before I install the intake/exhause.
Thanks.
GB1
Also if you are ported and using a header, consider a competition gasket.
10musketeer
I had a leak due to a weber header on the car and couldn't get it to seal on the intakes. Finally I resorted to a little fuel resistant/ high heat sealer and it worked well. I agree with the others, it is best to not use it and it really shouldn't be necessary, but if you run into any problems with aftermarket mods it will help.
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
Healey Nut Intake/Exhaust gasket Austin Healey 3
dklawson 1500 Intake/Exhaust Gasket - Siamese Ports? Triumph 10
N Which way for intake exhaust gasket? Triumph 1
B Intake/Exhaust Manifold Gasket Triumph 3
C Exhaust/Intake gasket sealer? Austin Healey 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
J New tube exhaust and intake manifold Austin Healey 15
J TR2/3/3A leak proofing intake/exhaust manifold Triumph 20
H intake and exhaust question Austin Healey 4
dklawson MGB MGB Intake/Exhaust Needed - [re-posting] MG 7
mgedit TR2/3/3A 56 TR3 Intake and Exhaust Manifolds Triumph 8
doughairfield Intake/exhaust manifold gaskets Triumph 1
bcbug removing exhaust/intake manifold Spridgets 6
R installing Intake Exhaust mainfold Triumph 18
W Replacing Exhaust/Intake gaskets and studs. Triumph 2
2wrench Opinion on intake and exhaust manifold studs Triumph 5
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
Brosky Studs for intake/exhaust manifolds Triumph 2
Brosky Intake and exhaust manifold powder coating Triumph 18
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
