Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
During installation of my new pistons and rings, I had to use the handle of a mallet to "rather" gently tap them past the rings. They just wouldn't drop in without the tapping. Was I reckless doing that? Was that expected?
Some tapping is required to get the rings out of the compressor (which is oiled) into the cylinder. The movement should be consistent, though, with no points where increased force is required to continue the motion.
Bob
I agree - I have the compressor pretty tight to be sure they go in to the cylinder easily, but that means some force needed to move them out of the compressor.
I always have to give them a good whack to make sure a ring doesn't catch and break. Make sure you use 'rubbers' on your rod bolts and protect the crank from any nicks. Lube everything up with your choice of motor oil...don't dip the pistons, just rub some on the pistons, rings, and cylinder walls and don't use anything more slick or the rings will have a hard time bedding.
Rut
The top of the cylinders should have at least a small bevel. If you haven't cut yourself on the top edge while working on the engine, I am sure your's does. The bevel allows the rings to pass from the compressor to the cylinder without catching too badly...although light to moderate tapping is normal. You did good using the wooden handle!
Gary,
Con rods can have sharp edges, protruding rod bolts, etc. that can damage the crank when the piston/rod assembly is inserted in the bore. They actually make little rubber or vinyl covers that slip over studs/bolts/con rod ends and most shops refer to them as rubbers. They actually extend a bit and help guide the rod onto the crankshaft.
Rut
