I'm getting some leakage from the cock valve cover gasket. I had used blue hylomar to bond the gasket to the valve cover then put a thin coat of oil on the side that mounts to the block. Normally this always works but I think i tightened the cover bolts a bit too much this time and am getting some leaks. I do have a silicone gasket that I have had for years but never got around to installing because it looked like it would be hard to get it to retain it's shape since it is not as stiff as a cork gasket. I'm going to give it a try Anyone tried using the silicone gasket and did you put the red RTV on the valve cover side and let it set up first before putting it on the block? How would you hold the silicone gasket there without it moving around?
