TR4/4A Installing a new windscreen
TRMark
Bronze
I am installing a new windscreen into the frame assembly before reinstalling on the car. I have been doing my research including the rope trick. I am not seeing any reference to the use of a sealant between the screen and the rubber or the rubber and the frame. The manual calls for a sealant. I would think the use of a sealant would make the rope trick very messy. Am I missing something?
When we installed our windscreen in the 250 we did not use any sealant. The rope trick works, But it is still a real PITA to get it in. It took my wife and I about two hours and a lot of bad words.
Best 40 bucks I ever spent was having a glass shop install the windscreen into the 'loose' TR4 frame.
Tricky enough when the frame is mounted on the car - a real handful when it is unattached (like yours and like mine).
I have installed several now. First it is best to do it either on the car body or some how have the frame mounted in a fixed position. Second the use of a foaming spray window cleaner to lubricate the seal and the front side chrome strip is a big help. Find a small diameter strong rope -- it works great.
Charley
Thanks, guys. I will check with local glass shops, I don't need to master every skill involved in a restoration.
I'll offer one bit of advice. The first time I did mine I cut the silver plastic trim so it neatly butted at the bottom and then covered the joint with the usual metal clip. Over the next few years that plastic shrank until the metal clip would no longer span the gap.
Next time I was smarter - I left about 2" of excess length there. It would wave in the breeze but I had a plan... I waited a couple of years and it slowly shrank about an inch or so. Finally, I cut the now shrunken trim to a butt joint and installed the clip. Unfortunately, it is still shrinking! The clip still covers the gap so maybe my initial wait was enough to prevent too big a gap - time will tell.
George,
TRF has three different lengths of those clips. Apparently because of the type of problems you are having.
Did you know that the early TR4s used a two piece solid metal trim?
Charley
I have the two piece solid metal for the front and the surrey back light. I plan on reusing them, the plastic that came with the rubber does not look "right." Doing the back light is going to be terrifying no matter who does it, unobtaineum.
You are correct about the rear window installation. The problem is with the bottom forward corner. I have two of these surrey tops. The first one was put on by a professional while I watched. He had a really tough time of it. The advice I would give is to put the gasket on the window and put it where it can get real warm and try your best to get the gasket to form around that curve in the window. I would do this like a week or more in advance and keep trying to find some way to get that gasket to form around that curve That was where most of the problems came from.
Charley
TonyPanchot Installing the chromed trim strip on windscreen Triumph 8
K TR2/3/3A Installing silicone valve cover gasket Triumph 6
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
KVH General Tech Reinstalling TR4A Interior Triumph 13
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
