Importing an antique auto from overseas
DanF
Does anyone have experience importing an antique auto from overseas? Can anyone explain the process or make recommendations ? For a newbie it seems rather complicated. I am hopeful that someone can simplify.
Thanks,
Dan
If it comes through the port in Bayonne, New Jersey get ready for some damage - those guys don't care...that's the experience I've had! Next time, I go through a port in Florida or south Carolina.
This topic has been discussed very often. I would think that you could find all of the information that you need by searching this site for previous postings.
Cheers, David.
Guys:
Tahnks for the info. I've tried searching and received mostly erronous info. Any help ??
Thanks,
Dan
Dan, what kind of vehicle is it and what country is it coming from? I will try and give you some information.
Cheers, David.
David:
Nothing set in stone . Europe incl. Italy and the UK would be the most likely spot. Before pursueing too much, I wanted to know what I was getting myself into.
Thanks,
Dan
The US Customs authorities have a web page on doing this.
I can't say anything about importing a car into the US, but when I brought mine out of the US to the UK I first called the UK Customs people here and spoke with them about it. They were very helpful, though your experience with those in the US may differ....
I also spoke with the shipping agent (international phone calls are now almost cheap, and certainly by comparison to the costs of not getting the information) and they were very helpful since they were the ones that dealt with the customs authorities. I asked the shippers who they'd use on the delivery side- and contacted those people directly to discuss details. It all went very smoothly....
Dan, first you need to be sure that the vehicle will be allowed in the States. You will need a perminet export paper from the UK. The log book will be cancelled...do not had it over to the DMV. Be sure that the car has DOT approved glass, tyre, etc.. Hire a broker on this end to handle all of the paper work for you. This is well worth the money as they will deal with customs, etc. and all you will have to do is have the car collected @ the shipper dock. Do not do a "drive on" journey. I would crate or put the vehicle in a container. Be sure to over inspect upon the arrival of the auto. Some packers are real hacks. I would think that the cost to you from the UK would be in the 2k region.
Cheers, David.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Do not do a "drive on" journey.[/QUOTE]
AMEN!!!
Because if you do, some dummy at the port will drive it off the boat into the storage yard, blaring the radio the whole time with the sunroof open not thinking that the battery might be low from the trip...then, when he parks it & the battery is too low to close the sunroof because he was booming the radio, he'll walk away & let it get rained into!! For days - or weeks - until you get to it!
Oh, yeah, David - been there done it a coule of times - still angry!
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The problem is that you are never made whole![/QUOTE]
Problem is you have to prove all the damage was done by them & did not exist before they got the car....my advice: photo every inch of the car in advance with dated photos.
Excellent advise, but probably still hard to prove if Mick did it on the UK end, or if Mike did it on this end?
Cheers, David.
I used to have some pics of the offloading of a nice older British car from the boat in Houston. It fell out of the sling/platform into 40 feet of water. Shipper told the owner his insurance for the trip didn't cover droppage into the harbor.
What a mess that was...couldn't even leave it there cause of the oil and fuel contamination. Owner eventually hired some frogmen (I think from the fire dept.) to go down and get some lines on it so it could be retrieved. Don't know what he did with it afterwards. He was letting it dryout first.
Check what the shipper or freight forwarder will insure.
Wombat
S importing parts to the U.S. Other British Cars 6
N TR6 ? about importing a TR6 from Canada to USA Triumph 9
W Importing MG's from the UK MG 9
macino62 Importing a car.... Triumph 2
macino62 Importing TVR Other British Cars 19
C purchasing and importing Minis British Motor Corp 8
K Importing To Canada Jaguar 1
K TR2/3/3A Antique Auto Parts to Canada= No Duty? Triumph 4
PAUL161 General MG Wanted Color chart for antique car paints Deep Red/Burgandy MG 7
Banjo antique tools score Restoration & Tools 2
S "ANTIQUE"???!!!!! Other Cars 23
6 Ohio Antique Plate Law Change Austin Healey 5
BobbyD Antique or Collector Car Plates Triumph 11
emann Pennsylvania Antique Tags Spridgets 1
kindofblue Antique Pllanes and Cars do mix Other Cars 11
TNMGB Antique plate pros and cons? MG 14
tony barnhill Antique Jag or Rolls in Newport, RI Other British Cars 13
aeronca65t antique ignition parts Restoration & Tools 0
aeronca65t antique lotus? Lotus 8
tr6nitjulius General TR 11/14/21 British Iron@Petersen Auto Museum Triumph 3
GB1 Classic Mini Mayfair Auto Other British Cars 1
sparkydave Zenith auto choke coming loose Spridgets 2
T General TR Ron's Vintage Auto Restoration - Salado TX Triumph 2
dklawson New [to me] Compressor - Water & Auto Drains Restoration & Tools 14
J Gas pump auto shut off question Austin Healey 2
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
R Auto Radiator Factory Austin Healey 9
maxwedge5281 auto transport recommendation Austin Healey 10
maxwedge5281 auto transport Austin Healey 5
sparkydave Zenith auto choke coming loose Spridgets 3
Rut TR4/4A O'Reilly Auto Parts Triumph 10
Rut O'Reilly Auto Parts Spridgets 8
dklawson Antra Auto Darkening Welding Helmets? - 2016 Restoration & Tools 6
bfitz Auto body supplier in JAcksonville FL Restoration & Tools 3
Marvin Gruber Auto Zone $15 freeze plugs Austin Healey 3
AngliaGT Which Car? Auto X/Hillclimb/Solo 1? Racing 2
B TR4/4A Advance Auto Wire for TR4A Triumph 4
coldplugs Question re auto subscription renewal FORUM Navigation Questions 2
HealeyRick Fun at the NY Auto Show Spridgets 5
aeronca65t Alternate Detroit Auto Show Other Cars 5
K 61 Mk1 auto to manual OD gearbox swap? Jaguar 0
C 2016 Jaguar XF released at 2015 Detroit Auto Show?? Jaguar 0
aeronca65t Various Cars. Local auto body shop Spotted 1
WillR MGB Rock auto close out MG 0
Geo Hahn General TR British Euro Auto Tour [BEAT] Triumph 2
DNK General TR Tech Auto Co. UK Triumph 0
Boggsy64 MGB Found parts at local auto store MG 4
I Off Topic Good auto body welder in Wa state? Triumph 7
L 1955 XK140 auto choke "otter" switch Jaguar 1
Pythias PDX-Auto Jumble.. 4-28. Spridgets 11
