How to tell Dunlop or Dayton
Patton
I just bought a used set of 72 spoke wheels for my Healey (forget that I said they look busy in another thread, I changed my mind).
How can I tell if they are Daytons or Dunlops? There is no rust, so I can't tell from that. Any obvious way?
AUSMHLY
From the photo where they are mounted on the car, I believe they are Daylops. A hybrid of Dayton/Dunlop.
Sorry, can't offer any help here.
Man o man, look at that offset.
You most likely have the wheel placed against the other in your photo, But I'll tell you, I've seen some cars driving around with wheels that stick out that far.
r
Patton
Patton
HA, it does make it look like I have very wide rims back there. Maybe I should get low profile tires as well!
Patton
Keoke
Hi Patton, This is not gospel,however I do not think Dulop builds that wheel in chrome only a painted version.---Fwiw---Keoke-?
GregW
The candy cane on the hood is certainly at odds with the way the rear wheel looks. I guess duellies are fairly common in Texas? /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
healeynut
It's hard to tell if they are dunlops or daytons, but my guess is dunlops.
I'd like to ask, is the white and pink jeep in the bottom of your photo for sale? That looks like a fun piece of equipment.
Patton
Patton
I just haven't figured out the best place to put the gun rack and the rollbar with the row of KC fog lights. Then it will be a true Texas Healey.
Patton
Patton
The only reason I really need to know is when/if I get a spare. I'll keep a 48 spoke in the trunk for a while.
You will have to talk to my 5 year old, Zoe. She really likes her Barbie Dream Jeep. The only issue is I disabled the "high" gear so she doesn't run down her little sister. If it stays in "low" the little one has time to get out of the way.
Patton
AUSMHLY
[/quote]
Now that's funny. And to back you up, my brother lives in Texas, and when visiting him, I have seen what you speak of.
Texas wisdom:
How do you protect Texas from attack? Armadillo.
John Loftus
Hi Patton,
Is there a reason you need to know or are you just curious?
From the Anderson/Moment book:
"The difference between Dunlop and Dayton is most noticable in the depth of the inner-most recess channel of the rim."
I suppose you could compare a known Dunlop/Dayton with these new wheels. You could also tell if/when you remove the tires as the Daytons should have sealing silicone around the spoke nipples and different edge bead for seating the tubeless tire rim.
I think Moss only carries Dunlop and they do have 72 spoke chromes in their catalog. This clashes with Keoke's post but a quick call to Moss would educate us on what they carry.
Cheers,
John
Patton
Patton
I got a set of 4, so one day I might want a matching spare.
I will take one to the NTAHC tech session this week and see if I can compare to someone's there. The guy I bought them from doesn't know either where they were purchased or how old the tires are. He just was told they were used for about 50 miles, then taken off.
John Loftus
Opps .. missed the part earlier about the spare. There is a way of determining the manufacture date on the tire. I don't know the codes off-hand but you should be able to search here or on the web. Or just wait a bit and someone will likely offer up the info /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Cheers,
John
Patton
Patton
[/quote] I don't know the codes off-hand but you should be able to search here or on the web. Or just wait a bit and someone will likely offer up the info [/quote]
Thanks, I know the old system, but don't know on newer tires. If what I think is the code is the code, they are only a year old! /bcforum/images/%%GRAEMLIN_URL%%/smile.gif They are 195/65's v the 185/70s I have on the car now, so I will have to see if they are OK with the clearance.
I think I also just figured out that they are Daytons as they appear to be tubeless. All good.
Patton
Keoke
Hi Patton, 195 X 65 X 15 tires are as close as you can get to the old hard to find 185 X 70 X 15 tyres. I mean really close.---Keoke
OK , here is the best information I have. The only Chrome WW Dunlop built in the 72 spoke configuration was a "15X5.5 Wheel. This was because at that time Dayton did not make that wheel in Chrome.--Fwiw--Keoke
Grantura_MKI
Dayton will build any wheel size, offset that you may require. I just sold 5 Dunlop Aquajets for $500.00, but they are for dispay only. I would not recomment extended touring on them.
Cheer, David.
John Loftus said:
Hi Patton,
Cheers,
John
nah that depends on what one gets rusty /bcforum/images/%%GRAEMLIN_URL%%/grin.gif first! dont forget dah steer horns on dah hood!
Keoke
/bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
Nope no clash 7777's note "At that time"---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
L Can anyone tell me what car this is from please? Other Cars 0
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
J anybody tell me why this thread closed? Austin Healey 4
matmire Curious if these photos tell you anything about my car. Spridgets 24
Boink You tell me... Spotted 3
D Bumpers and over riders, How do i tell if they are replacement or not Austin Healey 5
J How can I tell if I have a negative ground tach? Austin Healey 5
J How can I tell Austin Healey 1
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
JPSmit Viva GT show and tell - and a question Other British Cars 4
M gotta tell somebody Spridgets 10
J How to tell if your car is from the South... Spridgets 15
rkep01 How to tell if lever shocks need rebuilding? Spridgets 3
I How can you tell if a transmission is good? Spridgets 2
S Oh the stories this car could tell! Jaguar 1
M Tell me I need a fuel tank sending unit Spridgets 21
jlaird Miss Agatha was trying to tell me something Spridgets 4
I How can you tell if a starter is good? Spridgets 6
T How tell if gear reduction start fits is right? Triumph 2
R Austin but can some tell me what model, please? Spotted 5
I Can someone tell me what these are? Spridgets 12
drooartz Manifold vs carb vacuum - how to tell? Spridgets 18
T Why don't you guys tell me this stuff ;-] Triumph 10
F Compression test: What does it tell me Spridgets 6
T How tell if wire wheels are good? Triumph 7
T Can you tell what kind of car this is Triumph 9
R How do you tell if a rim is bent or warped Spridgets 1
T How tell if a used radiator is good Triumph 14
R Tell me this is not a big deal Spridgets 7
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
DrEntropy We're havin fun NOW I tell ya!! MG 26
JPSmit Show & Tell - tonites craft, luggage straps Spridgets 11
JPSmit Show and Tell - new carpet & progress Spridgets 44
RickB 5 speed trans, please look & tell me it is the one Spridgets 13
theleisure Silicone or Synthetic, How to Tell Spridgets 5
CCURTISS How to tell if paint is Enamel or Lacquer??? Restoration & Tools 7
I How can you really tell how old a tire is? Triumph 22
bthompson My turn for Show and Tell! Spridgets 12
kodanja Tell your worst TR horror story! Triumph 45
T Quick - tell me about your TR driving big miles Triumph 25
mrdibbles How to tell what year your Healey is? Austin Healey 14
58Custom How to tell diff btwn 1275 speedo & 1500 speedo? Spridgets 13
R Don't tell me I have to pull the *&%!#engine again Spridgets 13
AngliaGT How to Tell if an OD Trans MG 2
tomshobby show-n-tell Triumph 8
