TR2/3/3A How to remove the front brake hub from the brake disc?
karls59tr
Bronze
I have the assembly on the bench. I have removed the 4 bolts that hold the hub to the disc. What is the best way to remove the hub?
mastaphixa
Bronze
I believe there are 2 straight slot screws that hold the rotor on the hub once the wheel or splined adapter is removed.
K
karls59tr
Bronze
No screws. Just hit it with a hammer and it'll come off.
Hit it where? I'm trying to get the vertical link off but in order to do that I have to remove screws to the hub and I can't access those screws with the hub on?
auprichard
Once you remove the castellated nut on the stub axle (which it looks like you have) the hub and rotor/disc should simply slide off.
CJD
You must remove the wheel bearings. On the opposite side from the nut you removed, there is another nut with a cotter. The other end of the stub axle...under a cover. Remove the nut and the hub will pull off the stub axle with the wheel bearings and a lot of grease. Then you can unscrew the trunnion and work on removing the stub axle.
K
karls59tr
Bronze
The castellated nut with the cotter has been removed and the nut on the other end of the spindle has been removed. The four bolts that hold the hub to the rotor have been removed. The hub will not budge? Why is the hub frozen to the rotor with a death grip?
Hamish Racing
The stub axle will need a lot of force to come off the upright as it’s tapered.
you need to put the nut on the back/ inside - back on a little and persuade it off with a big hammer or even a press.
but with the front ( outside castle nut removed and the big plate washer out the hub should slide off with the bearings.
(note these pic are with my uprated stub axle yours will be thinner)
Hamish Racing
CJD
Then the hub, with the disc, bearings, and seal...should slip right off as a unit. It sounds like something in the seal/bearing area is locked up. Does the rotor/hub turn in relation to the vertical link?
K
karls59tr
Bronze
Yes the rotor hub spins freely! I may have to try and rig up another puller of some sort as the 2 prongs on the puller are not able to grip the edge of the hub properly???
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
drooartz Tools needed to remove front & rear suspension Spridgets 24
A Spitfire Can I remove the nut on the front of a Spit diff? Triumph 4
ahealey1004 how to remove front suspension inner bushings? Austin Healey 6
Atrus Driver Front Bake Line - remove rack? Spridgets 8
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
drooartz Bugeye jack points to remove rear axle Spridgets 18
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
