The best way is to fabricate a tool (you'll be in there more than once, trust me). The thread on the cap is 5/16" fine (24 TPI, I believe); get a length of allthread about 6 inches long in the correct thread. Get a coupler in the correct thread and either weld or glue it to the end of the allthread. Make a bracket/brace out of some sheet steel, and use a couple nuts and big flatwashers to apply against the brace after you've screwed the coupler to the 'bolt' on the cap.
Or, you can yank on it with pliers but that will ruin the threads on the cap (replacements are available, but ...).
