TR4/4A How do you go about reinstalling cylinder head?
tdskip
So ARP bolts here, believe I have the correct length ones in the correct block openings. Assembly lube on the studs, head gasket in place, and studs hand tight. Now just lower the block on the studs and torque to spec in correct order? Any other tips to pass along? Can you tell I an dreading having to do this again and am taking baby steps on the work?
Do you have the hardened washers, Grade 8 or better, soft washers will not give you the torque correct. Torque in three or four stages.
Wayne
And when you are all done, retorque at about 500 miles. You'll be surprised how much it may need to get back to spec.
Hi Wayne - I have the ARP fasteners but thanks for the tip!
Follow ARPs instructions and you'll be fine. I like to chamfer the stud holes and make sure everything's flat, clean out the holes really well, install the studs like you said making sure they are all the same height, slip on the gasket followed by the head and torque to ARP specs. Retorque after a few heat cycles and check your valves after...I do it again at 500 miles.
Report back on your success.
Rut
I assume the liner protrusion is good it's the most critical thing.
I was uncomfortable just hand tightening the ARP studs because the threaded holes were so "old" and gritty. So I got a gun rod cleaner with a little wire brush attachment and wound it down in the holes. Then I wrapped a little towel material soaked in oil onto a wood dowel to clean out what I'd done. Then I hand tightened the studs. I wanted to be sure that "hand tight" didn't mean I just got caught up on some old grit or rust. I don't believe I used any gasket sealant, and I use only the sandwich type head gasket--and a good quality torque wrench. Do check sleeve protrusion for about .005.
MGTF1250Dave Reinstalling Cylinder Head MG 3
KVH General Tech Reinstalling TR4A Interior Triumph 13
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
B Reinstalling 948 engine Spridgets 7
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
T MGA Grease axle stub before reinstalling hub on a MGA MG 2
T TR4/4A Prep before reinstalling TR4a gas tank Triumph 2
TRnorwegian Reinstalling the old Strombergs Triumph 2
TR4nut TR2/3/3A Question on reinstalling pinion flange on TR3A Triumph 8
T Reinstalling radius arms etc... Spridgets 4
zimmy reinstalling windshield Spridgets 1
G Reinstalling my Roller Rockers Triumph 4
J help with reinstalling the rear diffy on a 6 Triumph 8
B Reinstalling front springs. Spridgets 11
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
edkap2002 TR6 Cylinder shaped devise on top of fuel tank Triumph 4
C MGB Storing a cylinder head MG 5
K TR2/3/3A Cylinder misfire Triumph 7
Carlbanan56 MGB MGB cylinder head MG 11
K TR2/3/3A One more coolant leak cylinder head question..... Triumph 5
K TR2/3/3A Cylinder head liner protrusion specification? Triumph 1
6 Bench Bleeding a New Master Cylinder Spridgets 3
K TR2/3/3A Odd cylinder head core plug (picture). Triumph 7
K TR2/3/3A Mystery object in my cylinder head water jacket ??? Triumph 14
K TR2/3/3A Cylinder head valve stems and guides.... Triumph 3
K TR2/3/3A Cylinder head anomaly.... Triumph 15
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
