historical note on Piggetts book
MDCanaday
I just a copy of the very fine new book of Tr's by Mr Piggett.Looking at the production changes on the tr4's I was surprised to find that the last of the road draft vented cars was CT 14234 E.My Tr4 numbers matching motor was comm. #14275L this is 41 cars latter,but came from the factory with the vent tube. In all truth,when I had the engine down, it was very apparent that the motor block had been repaired at the factory before it was shipped.A square was cut out of the water jacket on the carb side, and brazed back shut, then machined and the head re-installed. This could explain why it came out after the cut-off.The British Motor Heritage says the car was built on 9 12 1962, with a motor # of CT 14256E .
I wish I had a good picture of the repair, it was the darnedest thing I have ever seen done to fix a casting flaw.This would make it the last road draft car to be shipped out of the factory.
MD( mad dog)
TR3driver
Great Pumpkin - R.I.P
Yup, the engine was pulled from the line for repair, then installed in a later car after being repaired. Such incidents were not uncommon, both for motors and entire cars. It's a common assumption that cars were built in commission number order, but many were finished out of order.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I wish I had a good picture of the repair, it was the darnedest thing I have ever seen done to fix a casting flaw.[/QUOTE]Me too! I wonder if the inserted square was the same one that was cut out, or if they cut a patch from another (scrap) block. The latter seems more likely to me.
M
MDCanaday
You are right Randal,the motor had to be brazed (in an oven ??),the square was all brass just over 1inch on all sides.it had been finished on the water side and the exterior,then milled (rather badly) for the headgasket to seat. It had only 52k on it when I got it and still had original hoses and even one original tire!You cant see the patch because of the exhaust manifold...As odd as it is, this never leaked or caused any problem with the gasket.
MD(mad dog)
G Historical Paint Question Triumph 24
Z Historical Big Healey and Sprite Photos Austin Healey 0
S "German" Jaguar of "historical" importance... Jaguar 2
drooartz Historical continuity British Motorbikes 5
Basil Important Note about Search Function - Please Read Other British Cars 0
Basil Important Note about Search Function - Please Read TVR 0
Basil Admn Note Important Note about Search Function - Please Read Triumph 0
Basil Important Note about Search Function - Please Read Sunbeam (Rootes) 0
Basil Important Note about Search Function - Please Read Spridgets 0
Basil Important Note about Search Function - Please Read Rover / Land Rover 0
Basil Admin Note Important Note about Search Function - Please Read MG 1
Basil Important Note about Search Function - Please Read Lotus 0
Basil Important Note about Search Function - Please Read Jaguar 0
Basil Important Note about Search Function - please read British Motor Corp 0
Basil >>> Important note about the search function - please read Austin Healey 0
Basil Important note from Basil Other British Cars 0
Basil Important note from Basil TVR 0
Basil Admn Note Important note from Basil Triumph 2
Basil Important note from Basil Sunbeam (Rootes) 0
Basil Important note from Basil Spridgets 0
Basil Important note from Basil Rover / Land Rover 0
Basil Admin Note Important note from Basil MG 0
Basil Important note from Basil Lotus 0
Basil Important note from Basil Jaguar 1
Basil Important note from Basil British Motor Corp 0
Basil Important note from Basil Austin Healey 0
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
Lin Ideal exhaust note! Austin Healey 7
rjc157 Exhaust Note Austin Healey 45
rjc157 Exhaust note Austin Healey 20
JPSmit Note to self Restoration & Tools 6
dklawson General Tech Cautionary Note On Clutch Life Triumph 2
rjc157 exhaust note Austin Healey 4
jlaird Just a note Spridgets 14
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
JPSmit Interesting drive home and note to self. Restoration & Tools 0
jvandyke mixture and exhaust note Spridgets 10
L Anyone using SUs take note [with pictures] Spridgets 5
T On a positive note - new Bosch alternator rocks! Triumph 21
bgbassplyr TR5/TR250 TR3,3A,3B,4, 4A, 250,6 NOTE..... Triumph 3
CraigLandrum TR2/3/3A TR3 Turn signal note Triumph 6
JPSmit Note to self - next time get a BE Spridgets 3
TR4 Really High Note Horns Triumph 4
Jim_Gruber Note To Self - How to start your Spridget on fire. Spridgets 11
BritCarFan Stag Wife gets goose bumps from exhaust note of Stag Triumph 1
D Horn Note ID Triumph 4
jlaird Intresting note Spridgets 8
T Crypty note for fun Triumph 8
S Exhaust Note Triumph 17
S BJ8 horns, high & low note directions Austin Healey 12
