Exhaust note
rjc157
This might be a stupid Question but what affects the exhaust not in our cars I have a nos ansa exhaust and for some reason it doesn't have that healey sound
There are two basic types of mufflers: 'turbo,' and 'glasspack' (or, possibly, some combination). The 'turbo' mufflers use baffles to muffle sound, while the 'glasspacks' have a sound-absorbent material; usually fiberglass or a steel wool or similar. Your Ansas are glasspacks--I know, I've performed surgery on them--whereas the original mufflers were probably turbo types (anybody know for sure?). Usually, the turbo-type have a deeper, rumbling sound while glasspacks typically have a sharper sound (for lack of a better term). Also, Ansas have 'mini mufflers' at the tips, which probably damps some of the higher-pitched sounds. Beyond that, the type and thickness of the steel used in their construction probably has an effect. Of course, the number of holes, if any, makes a difference.
Ansas are higher-pitched than OEM, I always thought they made my BJ8 sound more like a 6-cyl Ferrari.
Hi Ralph,
I have the same exhaust system in my lower slung BJ8P1 and every time I left my drive I would hit the resonator until the covering started to separate from the end plates. Although the leak was not obvious, it did change the exhaust note. I re-welded the end plates and retightened the connections and the exhaust note returned. I don't expect that you would have an obvious leak or you would have fixed it already. However, my indication that I did was from the type of exhaust note change you are querying about. Although the other components within the exhaust system can create a note difference, FWIW, I would examine the resonator closely.
Sorry Ralph, I misunderstood your question.
All the best,
Ray (64BJ8P1)
Well they will not sound like an NOS one.
Basically they are Helmholtz resonators where the sound is controlled by the shape and volume of the muffler. Packing and baffles are utilized to reduce the output frequency levels.
All the other variables presented in this discussion also come in to play.
I had a stainless steel muffler on my 100 that had no identifying marks on it so I can't say who made it but I always felt it was just over the edge of being uncomfortably loud and was most noticeable at about 60 mph and then quieted down quite a bit over that. Never having driven another Healey I figured they all sounded like that. When I crunched the muffler on a ridiculously tall parking lot hump (moving too fast before I realized how high it was, Yikes!!) it broke something inside and vibrated unbearably above about 45 mph. I pulled it off and cut it opened and all it had was a straight through baffle tube that had holes in it, nothing else. The tube had broken in half, thus the vibration. When I put on the NOS plain steel muffler I had in the barn that looks the same but is glass packed, it now sounds great and I love it. You can almost have a conversation at highway speed, but nobody would mistake me for a weeny on the road.
I had to drill all the holes in my frame for mounting the exhaust system and I was able to gain a little more clearance by assembling the whole system and raising it into position using a couple of 2"x12'x12" boards and a jack under each board. I then marked the best position for the exhaust hangars and then lowered the system and drilled the holes. My system hangs close and centered to all the underside. It was worth the extra time.
Back in the day I had a 1959 100/6 slash 3000. I sawed the stock muffler lengthwise on an aborted attempt to isolate the halves of the exhaust to make the exhaust note "sharper". Original muffler consisted of two louvered straight pipes surrounded by fibreglass. (Experiment failed). Bob
Wonder how it would have sounded with a separate muffler for each pipe? The six cylinder Healey was already a bit different by having a split manifold with two exhaust pipes which was a hot set-up for early 50s I6 American hot rods. But the American hot rods ran two glasspacks to the rear. Healey ran the two pipes back from the manifolds, but then combined them back into one muffler with dual inlets and outlets. Be interesting to hear one with true duals.
Yes Rick, my intent was to mimic the 6 cylinder Corvette. I had a girlfriend who had a '54 Vet whose previous owner installed glasspacs in place of the stock mufflers. The "rap" in those pipes was incredible as the exhaust note started out quite loud and then tapered off somewhat and came back around 4000 rpm with a vengeance. The Healey muffler with a sheet steel divider separating the two sides made no difference whatsoever ! I never checked but I'll bet the firing order was different between the Chevy and the Healey.
I do not know Rick but those mufflers also acted like a balance pipe.
Maybe even better with a crossover pipe to connect the two exhausts on BJ8's?
Here again-Patrick
This setup eliminates the need for a balance/crossover pipe which can complicate exhaust system servicing.
Late BJ8 cars use separate mufflers but met German noise acceptance levels without Crossover pipes.-:applause:
OH!! Daimler V8 saloons got crossover pipes-:wink-new:
My ANSA exhaust system has separate free-flow mufflers and piping but comes together in the resonator. The shared resonator has 2 inlets and 2 outlets so I don't know if it functions, or could function (given the distance from the engine), to balance the exhaust.
Ray (64BJ8P1)
Ray (64BJ8P1)
Well Ray:
If we accept the concept that the balance pipe equalizes back pressure in the system your resonator may qualify.
However, I have no experience with that aftermarket exhaust system .
Well Ray:
I believe it was Smoky Yunik who came up with the idea of a crossover pipe to increase hp in his stockcar.
The problem there is a crossover pipe would make the BJ8 even quieter. IMO BJ8s are already too quiet.
My Bell stainless system has a nice mellow note. As more carbon stuff get's into the muffler it will no longer have any of the stainless sound(I'm told}.
My BJ7 is equipped with true dual exhaust - two separate 4 in. glass packs on 1 3/4 in. piped straight to the back. System sounds great - albeit a little loud at highway speeds. As an expensive "experiment", a SS exhaust system was installed and tested for two months, but the sound was reedy / tinny and performance dropped noticeable compared to the true dual exhaust.
Digging the pop and fizzle of a 6 cylinder engine on dual / straight-through exhaust - loud and proud!
SS system is now garage wall-art. Down pipes are beauties! Gonzo.
If the original muffler has a perforated/ventilated central bulkhead which allows the two sides to co-mingle then that will act as a cross over pipe. this will smooth out the pulses and also lower the decibels alittle. I built a new engine for my '70 Vette last winter and did alot of home work along the way. One of the books I read claimed that a crossover pipe will smooth things out considerably but doesn't necessarily contribute to more horsepower. This was the ultimate conclusion of alot of dyno testing. I have been running 2.5" straight chambered pipes down the center of my '70 Vette for about 5 years without a cross over pipe. It sounds mean under 2500 rpms but at highway speeds the resonance is ah, what should we say, very vibrant. You can bet when I put it back on the road later this year it will have a crossover pipe. Dave.
Lin Ideal exhaust note! Austin Healey 7
rjc157 Exhaust Note Austin Healey 45
rjc157 exhaust note Austin Healey 4
jvandyke mixture and exhaust note Spridgets 10
BritCarFan Stag Wife gets goose bumps from exhaust note of Stag Triumph 1
S Exhaust Note Triumph 17
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
