High milage Oil opinions
jerrybny
I am curious what people's thoughts on the high mileage oil you see being sold. I see that Castrol has a 20w-50 high mileage oil. Is it any better than the regular Castrol 20w-50 oil? Thanks
I think they contain additives to control oxidation..
I have a Cat diesel with 1,540,000 miles on it...and almost 1,000,000 miles since it was overhauled. I use 15W40 Mobil Delvac oil...no one makes high mileage oils for these HD diesels...makes you wonder why they do for autos...could it be MORE PROFIT?
Nahhhhhhhh...
Some high mileage oils may also contain an additive to reduce leaks... something that softens old seals. That won't do a darn thing for that leaky scroll seal at the back of a TR crank.
I almost bought the high milage castrol but took it out of the cart, refusing to be a victim of marketing (in this case,atleast). Oil is the best thing for seals...make sure your engine has plenty.
I was just thinking of how the "old-timers" used to regard detergent oil back in the 50's and 60's.
They all thought that you'd have bubbles coming out of the oil filler if you used it....
In the service station that I worked in in the early 60's, we always had a hard time (and often futile time) convincing these guys to use even a single-grade detergent oil..much less a multi-grade!
Carlbanan56 MGB High beam problems MG 4
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
D TR2/3/3A Alternator dial runs high Triumph 5
steveg High quality hose clamps Austin Healey 3
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
W Tachometer reads high when engine compartment heats up Austin Healey 3
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
4tecdog Misfire at high revs Austin Healey 21
warwick-steve Steering high spot - midway Austin Healey 17
warwick-steve High compression head identification Austin Healey 16
J TR4/4A High Water marks? Triumph 5
John Turney Another High-Priced "100" Austin Healey 11
D High beam Lamp Spridgets 3
D 69 E Type High Idle Jaguar 9
B TR6 TR6 High Oil Pressure Triumph 20
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
B mgb taking the high road Spotted 0
B '67 BJ8 to high Austin Healey 18
