Hello,
I have a recently restored bugeye which I finished last summer. Everything is like new for the most part. It has started up fine until a week ago. Now, when I pull out the starter switch, the dash lights dim, the instruments go dead, and I get nothing from the starter. When I ran a wire directly form the battery to the starter, it did the same thing. Doesn't this indicate a bad starter? I did pull it and bench tested it a few months ago.It seemed to work fine then. It is NOS, but I still think this is my problem. The battery is fully charged, and I have checked grounds which are extremely clean. I admit I am very frustrated at this point. Any ideas would greatly be appreciated.
I am trying to keep things stock, but I have heard this is typical behavior for a bugeye starter. If this is true, can some point me to one that is reliable and a source? Thanks for your time.
Kevin
Kevin
