Help..Brake Light/Switch Problem
BASS
Ok guys, here is my problem..My brake lights didnt work, so I took out the old brake light switch, and it turned out the old one is bad (the center pintle piece was rusted and didnt move)..I ordered a new brake light switch, and when I installed it, only the passenger side brake light works..
So, this is the problem now: With the parking lights off and the brake light switch on (i.e. the center pintle not pressed in), the passenger side brake light is on (bright) and the driver side light comes on (but dim).
With the parking lights on and the brake switch on (i.e. center pintle not pressed in), only the passenger side light becomes bright and the driver side light totally shuts off. When I press the center pintle in (i.e. brake switch off), the rear parking light go normal (i.e. both become dim).
What can be the problem??? Faulty brake light switch? It seems it doesnt matter which way I connect the switch either, is that correct? I checked all the connections and everything seems ok..Im really confused!
Bad ground on the dim tail lamp.
Or you have the red and grn/purple wires crossed at the connections.
The brake light switch only powers the grn/purple wire which should run to both tail lamps.
Or by some slim chance you have the wrong bulb and it's in backwards.
Should be an 1157 bulb.
Thanks Spritenut..So, wheres the ground for this dim tail lamp located (along the inner body panel in the trunk?). Also, does it matter which way the brake light switch is hooked up? (the new one has two green wires, and the connector on the car has a green wire and a green with purplish/white strip on it...
Also, its the correct bulb and I even swapped out two other ones with the same result..
I checked all the connections and they were good. This is what it looked like on the driver side right after the harness splits to the lights:
Red wire splits to the rear side marker light and the top part of the tail lamp.
Green/Purple wire goes to the green/purple wire on the tail lamp.
Green/Red wire goes to an all green wire to the rear driver turn signal (i.e. bottom bulb on the rear tail lamp)
Black wire goes to the black ground on the rear side marker.
Does that seem correct? I checked all the wires on the other side, and its a little more confusing/more wires on the passenger side, but everything seems to be connected tightly..
Can it be a bad brake light switch??
OR, maybe the green/purple wire and the red wire connections are reversed right behind the bulb holder???
The tail lamps ground via the bolts that hold them in.
Clean the paint off at least one slot on the inside of the trunk where the lamp nuts go.
It doesn't matter which wire, one is hot, the other goes to the lamps. Power in, contact, power out.
What year and model car do you have? I fthe brake light switch only has two leads and it is inline with the brake lines it doesn;t matter which way you hook it up. It sounds as if you have the wires crossed at the light that doesn't work properly. The other lught has to be burnt out. Have they worked before?
Okay, I just read your original thread again. I don't understand exactly what you are saying. Check the bulbs and then hte wires you have running to the actually lights. My original question stands.... where these lights originally working okay? Or are you getting this going for the first time?
Spritenut, you were correct!! I just went out there and tightened/cleaned one of the bolts that hold the tail lamp on, and viola, it works!! Thanks so much!! This forum is awesome!
And when Spritenut speaks we all listen.
I Brake warning light stays on - help please Triumph 28
I Brake light help Spridgets 41
M HELP- Brake Light Switch Jaguar 5
R TR6 Help: Brake Part Source or …. ? Triumph 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
M Brake Drum Help - 60 Sprite Spridgets 88
C Help diagnosing rear brake issues... Austin Healey 20
R Help with BJ7 front brake line routing Austin Healey 6
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
J E brake help forgo many Big Healey owners Austin Healey 8
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
N Need Brake Bleeding Help Spridgets 25
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
B MGB Dumb emergency brake questions...help requested! MG 5
T TR2/3/3A Help on handbrake boot for TR3 Triumph 2
T Clutch and Brake Help Spridgets 13
CZ_Dave T-Series Need Help, Clutch/Brake MC on 1959 Magnette MG 3
6 Rear brake help needed Austin Healey 10
B Brake bleeding issues....Help please... Triumph 16
C 100-6 Resto-Mod Nasty-Boy Brake Upgrade - Help... Austin Healey 2
R HELP! Wheel brake cylinder clip MG 9
I Bugeye hand brake help please Spridgets 8
I Brake help please - this can't be good. Spridgets 21
1 Rear Brake Help Please Spridgets 6
M Help needed to ID brake lines Triumph 5
veale001 Brake MC Help.................................... Triumph 6
M T-Series MG TD brake help needed, please MG 3
I Help ordering brake lines for Bugeye Spridgets 7
Tinkerman TR2/3/3A TR3A Handbrake Help Needed Triumph 9
B Brake union Switch Triple Master HELP!!!! Racing 5
T Hand Brake help needed. Triumph 17
A brake servo booster help Triumph 3
1 BE handbrake removal help......... Spridgets 14
I Brake fluid help Triumph 3
W Help with Brake MC Spridgets 18
E Help...brake line question. Spridgets 16
Michael Oritt rear brake parts identification help needed Spridgets 1
Michael Oritt Rear brake parts identification help needed Racing 6
tosoutherncars HELP #2 - rear hub / brake rebuild Spridgets 21
S HELP! with vacuum brake booster Austin Healey 4
C Brake rotor help Racing 3
C Brake rotor help Lotus 2
C Brake rotor help Racing 9
fmichaels brake line replacement help! Spridgets 16
vping Brake master help Other Cars 8
Stewart Help Brake servo has me stumped MG 3
