gear box/ OD oil
I'm using Redline 90m gear oil in my BJ8 and I just read in the Healey Marque (by Norman Nock, Oct 2004) that it should be 30-w-50. I've had no problems and I feel it is actually an improvement. What do you all feel?
I used 20-50 motor oil for a while & thought it was pretty good. Switched to Redline MT-90 which is a SAE 75w/90 GL-4 gear oil & equivalent to SAE 10w/40 motor oil, & found easier, smoother shifting & the OD shifts a bit faster & more positively. I have also tried Redline MTL which is a SAE 70w/80 GL-4 gear oil & equivalent to SAE 10w/30 motor oil. I can't tell much difference between the two Redline oils. They both work noticeably better than the previous SAE 20w/50 motor oil. I attribute the better performance to the higher coefficient of friction of the Redline oils which lets the synchronizers & OD clutches work better.
I will always use redline MT90. I tried others but RL make it shift better same as Dave's comments.
Tracy
[ QUOTE ]
Dave, had you seen that article?
[/ QUOTE ]
I went back & read the article, just glanced over it the first time. I think some folks don't realize that engine oil & gear oil have two different viscosity rating systems. Thus 75w/90 wt gear oil is equivalent in viscosity to 10w/40 wt motor oil etc. I think that engine oil viscosity is rated at 210 degrees & gear gear oil viscosity is rated at 100 degrees.
Redline MT90 & MTL are GL4 rated oils which means that they doe not contain the sulfur compounds found in GL5 rated oils. They have a higher coefficient of friction than a GL5 rated oil. This helps the synchronizer rings in the transmission to work more efficiently.
The sulfur in GL5 rated oil provides necessary protection against the shearing/sliding motion that occurs with hypoid type gears in a rear axle. Hypoid gears are always in a sliding motion. There is very little shearing action & much less friction in the transmission than in the axle so this type of protection is not needed. The sulfur compounds in GL5 tend to damage brass/bronze parts such as the synchro rings in the old Healey transmissions. So the general warning to not use gear oils in Healey transmissions. Many available rear axle oils state that they are acceptable for GL3, GL4, & GL5 usage. These oils obviously contain the sulfur compounds which may damage the brass synchro rings.
Triumph suggested gear oil for a similar transmission, but this was before the advent of available GL5 rated oils which might have caused problems..
Quote: So the general warning to not use gear oils in Healey transmissions.
Dave, so you are suggesting that using Redline MT90 in the transmission is not a good idea? I was under the impression that most were using it.
I said:
"Redline MT90 & MTL are GL4 rated oils which means that they doe not contain the sulfur compounds found in GL5 rated oils."
Also:
"The sulfur compounds in GL5 tend to damage brass/bronze parts such as the synchro rings in the old Healey transmissions. So the general warning to not use gear oils in Healey transmissions."
RL MT90 is a GL4 rated oil with no sulfur, & thus an exception to the general warning, & can be used in transmissions. MT90 is not suitable for use in hypoid rear axles. Sorry I didn't make it as clear as I should have.
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
J TR2/3/3A Gear oil in the gear box? Triumph 13
J Healey Gear Box & OD oil Racing 5
A Gear box oil MG 9
ekamm gear box oil Triumph 13
W Silly question Gear Box oil change/top up MG 11
LuckyLuke Right Oil for BN1 axle and gear box Austin Healey 4
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
A TR4/4A TR4 gear box oil Triumph 13
W MGB MGB GEAR BOX OIL. MG 7
L T-Series Gear box servicing cap. MG 5
Todd78d Sprit MK1 gear box filler Spridgets 2
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
D Socket for TR3 Gear box drain plug Restoration & Tools 6
F BN1 vs Bn2 gear box Austin Healey 23
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
Got_All_4 General TR Problem mounting the a type to the gear box Triumph 12
K TR2/3/3A Gear box to Motor Bolts? Triumph 6
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
Got_All_4 TR2/3/3A Removing the J type unit from the gear box Triumph 24
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
D gear box fill plug Triumph 13
andrea $ SPEED SIDE SHIFT GEAR BOX Unknow spare piece Austin Healey 3
tahoe healey Gear box woes Austin Healey 10
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
Got_All_4 TR2/3/3A Prize in every box! TR3 gear box Triumph 30
W Over drive gear box MG 0
J Gear Box Jaguar 10
tahoe healey Fillintg the gear box on a BJ* Austin Healey 3
TRnorwegian Japanese gear box better? Triumph 29
R T-Series TC Steering Box Worm Gear MG 1
mountainman TR2/3/3A TR3 STEERING GEAR BOX FLUID Triumph 5
Tinkerman TR4/4A Cluster gear removal TR4 syncro box Triumph 2
J Speedometer housing at gear box Spridgets 2
Tinkerman TR2/3/3A TR3 gear box shaft selectors Triumph 6
Tinkerman Cleaning Tranny, OD and Gear Box Covers Triumph 9
B Gear box whine MG 11
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
M Gasket sealer on bell housing to gear box Austin Healey 13
M Steering gear box zerk fitting Austin Healey 16
tahoe healey big gear box problem Austin Healey 7
A TR4/4A TR4 gear box question Triumph 4
tahoe healey Gear box dip stick Austin Healey 2
R Gear Box/Stick Problems Austin Healey 5
W O/D Gear Box Or Not MG 28
W 5 Speed conversion gear box MG 3
A TR2/3/3A TR3 gear box dismantle question Triumph 1
A TR4/4A Converting TR4 gear box to O/D Triumph 4
tahoe healey gear box drip Austin Healey 7
