Exhaust systems/ mods
TonyPanchot
Hi all
I have a Monza system that I installed a few years back
and wow is it still loud even though I dont drive the 250 that much, was wondering what or if I could install a glass pack prior to the Y pipe
would this quiet things down a and any recommendations on a brand ??
THX,
Tony
poolboy
Glasspacks:
Baffle:
The glasspacks are just about as freeflow as you can get and pretty loud. I took a page from motorcycle drag racers book and installed baffles both to add some back pressure and quiet the sound.
The baffle as pictured was still a little too loud so I wrapped the smaller diameter part with asbestos webbing that I've had for years and that gave me just what I wanted , a nice drone at cruising and a mean sound on hard acceleration. I think the added back pressure improved acceleration too.
I suppose header wrap or even fiberglass in one form or another would work just as good as the asbestos webbing.
poolboy
If your Monza's are not rusty, you can probably just add baffles to your tailpipes and notice a difference.
TonyPanchot
TonyPanchot
Thanks PB, my Monza's are very fresh, where might I acquire such devices
kinda reminds me of the spark arrestors that always rusted out on our motocross bikes back in the day
Andrew Mace
Glasspacks vary, I suppose. Many years ago (ok, 26 years ago), a buddy and I resurrected an old G-prod '64 Spitfire to use as an autocross car. Knowing that we'd be running mostly parking lots, and that some had "sensitive" neighbors, we used some straight pipe from the header and hung a small Thrush muffler under the boot. Turned out really to be no more offensive than some of the "stock" cars that showed up!
poolboy
Ebay Motors. just search for "baffles".
You'll find them in various lengths (mine were 4" long) and various diameters.... And various versions.
I imagine that some cycle shops would have them as well.
TonyPanchot
TonyPanchot
did have a thought !!
what about simple glass pack forward the Y pipe
would this retain too much heat under the floor pan ??
Keoke
TR4A_IRS
You could install a muffler between the downpipe and the Monza system you have. I think item 2 on the moss diagram would work for your 250.
Midpipe Silencer
I went this route on my 4A with a Monza exhuast (using the 4A midpipe silencer which has two inlets) and it helped considerably.
glemon
When I had a 4A I added the monza exhaust and thought it was too loud, I added the midpippe silencer as shown on the moss page referenced about, item 26, I believe this would be the one you want if you have the dual downpipes.
It went from too loud to just right, louder than stock but not obnoxious, with the additional muffler.
V
vagt6
One possible solution, although maybe pricey, is to copy the silencers used on current performance cars. For example, a friend of mine here was looking for an exhaust system for his MG and came up with the silencers (mufflers) from a new MINI Cooper JCW exhaust system. I think he found it at MINI Mania.
The JCW (John Cooper Works option with reworked head, exhaust, headers, etc.) system is compact and the actual mufflers are relatively small. It has a very sporty sound, and is louder than the MINI S that I drive, but it's acceptable. Maybe a bit too loud for my tastes, but he wanted something sporty and is very pleased with the system.
Most importantly, it fits nicely under the MG. I suspect it would fit under other LBCs as well.
Maybe worth investigating? I hope this is helpful, let us know what you decide.
3798j
Bronze
I've installed one of these: https://www.jegs.com/p/Dynomax/744696/10002/-1. It's only an 11" case and is installed right behind my 4 into 1 header and before my stock TR4A "Y" pipe and stock twin resonators. It got my exhaust volume and tone to where I wanted, plus was economical ($24.00) and it looks like it was designed for the space available.
S TR2/3/3A Exhaust Systems Triumph 10
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Simmo MGB Exhaust Systems MG 10
BOBBYR Exhaust systems ? Austin Healey 2
T Swapping exhaust systems on a Sprite Spridgets 3
R E Type Exhaust systems Jaguar 2
G SS Exhaust Systems - BELL vs. FALCON Austin Healey 13
R exhaust systems MG 1
tahoe healey stainless exhaust systems Austin Healey 3
7 Exhaust systems MG 17
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
