Exhaust Man. Gasket
Tomster
This was found by the shop who is servicing my 4A, when they started to replace my exhaust manifold.
Amazing!
I wonder if I will:
Get more power?
Have fewer occasions of run on?
Better operating temps?
Improved mileage?
Bigger smile?
swift6
WOW! There's something you don't see everyday. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Brosky
Very, very interesting. Kind of reminds you of the old 1960's JC Whitney "Gas Misers" that went into the intake, under your carb(s) to "supercharge and atomize" the air/fuel mixture for increased power and gas mileage.
End result was many vacuum leaks and bonus business for good shops, fixing back alley repairs. Sadly, as usual, the consumer got porked.
T
Tomster
I know, I am amazed that there was actually enough space to blow out the exhaust gas.
Spring diving will be some kinda special after this little discovery!
- 30 here tonite with heavy snow and wind.
Our first real blizzard in a long time
Yes, I am spending a lot of time on the thru the windsheild thread
martx-5
I make a lot of tooling, fixtures and small machines at work, and one of the things I constantly have to be aware of is how to make everything as idiot proof as possible. If there is a way to screw something up, the average worker will find it. All the Triumph engineers had to do was make the bolt pattern in a rectangle instead of a square, and this never would have happened. /bcforum/images/%%GRAEMLIN_URL%%/eek.gif
BTW, your new found power should really give you the giggles. Man, that engine had to be gasping for air...like stuffing a potato in the exhaust pipe. Reminds me of the old two cycle Saabs. I used to work for a Saab dealer, and you could hear the engines gasping as the customer drove up, looking for a tune-up. Well, we knew by the sound that what the car really needed was a new exhaust system because the old one was just totally plugged up from all of the oil vapors that the two cycle pumped out.
G
I wonder what condition your exhaust valves are in? No were for all that heat to escape.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]how to make everything as idiot proof as possible[/QUOTE]
I learned long ago, if you try make it "Idiot Proof", someone will make a better idiot to get around your efforts. /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
T
Tomster
TR6BILL:
Do Not Go There
Step quietly away from your keyboard!
Brosky:
The factory of the future will be run by a man and a dog.
The man will be there to feed the dog.
The dog will be there to make sure the man doesn't touch the machines.
[Dr. Barry Asmus]
AltaKnight
Hard to believe it would even run like that, looks like only about 10% open area for the exhaust gas.
I guess I'll be able to spot you driving around Edmonton by the new found speed this summer Tomster.
Seems like a long way off; snow was drifted 3 ft high on my drive this evening, 60MPH wind gusts with snowfall mixed in.
Still, I got to play with my 10HP snowblower; but helping Tinster locate his car and getting it to go is starting to look real attractive right now.
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 9
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
AUSMHLY Exhaust leaks Austin Healey 14
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
