Exhaust gas analyser - what carbon monoxide level should I expect from my BT7?
fishyboy
Hi all,
I am thinking of buying an exhaust gas analyzer (Gunsons, https://www.gunson.co.uk/product/G4125) to help with getting the mixture right on my BT7 twin carb. I currently use two Gunson Colourtune's ( in cylinder no. 2 and 5) but always feel the mixture is too rich despite getting a blue colored combustion.
While I understand the I could use the exhaust gas analyzer to match the CO output from the two tail pipes (assuming they are each fed from separate carbs I am less clear about what the ideal CO % should be. I have read anywhere from 1-6%?
Does anyone have any experience of using a Gunson's exhaust gas analyzer? Also does anyone know what the optimized CO level should be for a BT7?
thanks
Phil
Phil Says:
"I am less clear about what the ideal CO % should be."
The CO% level that passes the Bloody MOT! :devilgrin:
I would get a dual-channel wideband sensor and gauge. Put an O2 sensor in each downpipe and you can constantly monitor the air/fuel mixture of each carb at all places in the rev range. The ideal lambda ratio is between 13.7 and 14.5.
I have an AEM wideband system in the race cars and an APSX system in my vintage BMW. So far I have not taken my own advice on the Healey.
Keoke
The UK MOT only requires a visual inspection of the exhaust gases for pre-1975 engines. No CO% is measured.
Gearhead
The device I'm looking to buy only measures CO%
Searching around the web I found the attached table of air-fuel mixture (AFM)v CO%. Ideal combustion is at AFR 14.7 which equates to 0.1% CO. Most folk appear to settle on a CO 1-4%.
Phil
14.7 is ideal but you always want to be just a bit on the rich side to prevent detonation so optimal Air/Fuel readings would be 13.7 - 14.5.
from a very practical, non-engineering point of view I would say that for a car such as a Healey that the readings are going to be relative. Meaning the best you can get. I'm guessing that with a stock engine, including intake, carbs, exhaust you won't get near an ideal set up. To have good driveability and no pinging it is going to be on the rich side. Once you come up with a setting that works then that would be your mark to tune by from then on. I've thought about buying some type of analyzer to tune with, it would be a great tool. But ya know, the lift the piston method on the carbs does the same thing. Setting mixture with a tach is also very effective.
... Does anyone have any experience of using a Gunson's exhaust gas analyzer? Also does anyone know what the optimized CO level should be for a BT7?
thanks
Phil
I bought one and had no luck with it. IIRC, I couldn't get consistent readings, and the plastic tube you stick in the tailpipe melted. If you've got 'bunsen blue' with Colortunes just lean the carbs a little and see if it pings.
Mine runs best just on the yellow side of bunsen blue. Have a hill near my house and coming down it should just burble. Backfiring is too lean.
I have a switched K&N Air/fuel meter with an O2 sensor in each downpipe. This is mainly good for showing me if one of the carbs is acting differently from the other during acceleration mode.
R Moss Exhaust Gas Analyzer Spridgets 3
R Sun Exhaust Gas Analyzer Triumph 0
R Sun Electric Exhaust Gas Analyzer Austin Healey 0
R DEQ testing/passing & exhaust gas analyzer Spridgets 7
R ColorTune and Exhaust Gas Analyzer MG 6
Bret Exhaust Gas Analyzer?? Restoration & Tools 3
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
