Engine paint color....conundrum
lbc_newbie
OK, I have a 78 MG Midget with a 1275 in it (not the 1500). Just getting it back from the shop for assembly and would like some feedback on a proper color.....Not black or orange please! I am partial to the metallic green. Recommendations on primer (will Rustoleum suffice?). Does it really need to be heat resistant? One would think that if your engine got hot enough to peel paint, you have a bigger problem!
(in hind-sight, I guess it's kind of silly to ask for a "proper" color for an "improper" car)....open to thoughts.
tony barnhill
Great Pumpkin - R.I.P
Whatever you want - you've already personalized it with the 1275 so, go for it!
drooartz
As you may know, there really isn't a proper color -- even when new the factory used what was around, so the greens are not all the same. Pick what you like and go for it.
I do like that lighter Healey green color.
Pythias
Paul A. has the proper Olive green for A-Series engines. Ask him to bring you some on the 18th.
Here's a Aseries engine I built with the big healey met. green, I use dupli clor engine hi heat primer, Moss healey emt. green, then Duplicolor hi heat engine clear, it make for nice finish.
JPSmit
your car your choice
Ms Triss 1500 - "proper" green
I know we have a gators painted engine - oops I mean Auburn
jlaird
And of course a proper one.
x2 ... Yurple. :smile:
jvandyke
Ford blue isn't all bad.
Here's Drew's beast, I still love the looks of this motor, it just lloks right., then one of Ray, same look, more bling.
Another look, you don't see that much on A series engine, but I think it would look really good, MG maroon.
OK, here, a common colr with a twist, this is a specific supercharger built MGB motor I built, the paint iis the shinieist I ever saw, the customer supplied me with it, it's Hirsh engine paint, sprayed with a gun. Check it out with all his chrome and goodies bolted on.
drooartz
I'm rather fond of that look myself.
Here's another shot that really show the shine of the Hirsh black paint.
bugimike
I am partial to Cummins beige! I think that would also look good in a green car. I like it because leaks are easy to see against it (and it is a neutral color that "goes" with everything!
19Sprite65
Along this vein of engine colors: my '65 tranny shows no signs of ever being painted. I've seen photos both ways- anyone have a clue?
Marvin Gruber BJ8 engine paint color. Austin Healey 25
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
M Poor Dupli-Color engine enamel paint results Triumph 13
N 1964 sprite engine paint color Spridgets 3
S Mini engine paint color and pics needed British Motor Corp 9
MadRiver Engine color and paint? Triumph 15
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
B Engine paint Austin Healey 17
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
KVH TR4/4A Engine Paint Triumph 3
B Engine Paint Austin Healey 13
jlaird Engine paint Spridgets 16
N Engine paint??? Spridgets 11
H engine paint question Austin Healey 19
Magyar T-Series MGTF Dark Red Engine Paint MG 7
K engine paint Austin Healey 5
S engine paint help Austin Healey 2
TomMull Engine Paint Triumph 6
A question about media blasting and engine paint. Austin Healey 14
BOBBYR Por-15 engine paint Austin Healey 7
M Engine Paint Austin Healey 4
J Engine component paint Austin Healey 3
J Body/Engine Paint codes....? Austin Healey 6
PAUL161 T-Series Engine Paint for a TF? MG 10
chrpark engine paint Spridgets 16
B Engine Prep for Paint Austin Healey 2
M Engine Block Paint Triumph 16
Trevor Jessie Engine Paint Spridgets 8
T 1955 100-4 Engine Paint Austin Healey 8
R Engine paint Triumph 19
JeffS looking for PPG engine green paint code.... HELP! Austin Healey 9
M 1275 Engine Paint Schemes? Spridgets 7
B Question on paint typs for engine parts? Restoration & Tools 16
glemon Moss Engine Paint Application Austin Healey 5
B "Original" Healey engine paint? Austin Healey 10
R BN1 engine paint Austin Healey 7
tateboys Why paint engine compartment black MG 33
C Engine Compartment Paint - Do-Over!! Triumph 6
C I finished paint the engine compartment tonight!!! Triumph 7
S Frame and Engine Compartment Paint Austin Healey 7
F Engine Paint...powder coating or just high temp? Triumph 7
A Spitfire 78 Spit - Correct engine/suspension paint? Triumph 4
W Morris Green Engine Paint Code Spridgets 4
jlaird Per previous discussion on engine paint Spridgets 0
S TR2/3/3A $10 in spray paint vs. TR3's engine bay Triumph 10
M Engine Bay and Rattle Can Paint Triumph 9
KLUTZ Brush paint for engine bay? Triumph 15
fmichaels engine paint Spridgets 10
Tullamore Engine Paint Spridgets 8
