Engine Paint
Tullamore
Where do I buy the silvery-green engine paint that this article says was used on the later engines. This is the color my air filter, oil pan, and valve cover are painted now, I want to sandblast them and repaint them to be perfect.
https://www.minimania.ca/MM/1275cc_A_Series_Engine_Color_Schemes__Sprites___Midgets_603.htm
Here is a shot from my car, if this is not what the stock color should be for a 1969 Sprite let me know. I am confused on if it should be this blue or the grey.
For a '69 Sprite the correct engine color is the light 'hammertone' green, aka, the big healey color, not the 'olive' or 'Morris' green. Your air filter housings should be gloss black.
The engines were painted as a unit. They should be the same hammertone green if that is what is correct for a '69. I'm surprised that that is the correct color as I have never seen an A series engine painted that color. I learn something new every day...
Tullamore,
I'll add this to my earlier statement to engine color. If your engine number begins with "12CE" or "12CD" the lighter hammertone green would be the correct color. "12CC" engines were the dark(er) green.
Yes the entire engine would be painted the same color. For the correct engine color I consulted Horler's OS&M.
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
B Engine paint Austin Healey 17
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
Marvin Gruber BJ8 engine paint color. Austin Healey 25
KVH TR4/4A Engine Paint Triumph 3
B Engine Paint Austin Healey 13
jlaird Engine paint Spridgets 16
N Engine paint??? Spridgets 11
H engine paint question Austin Healey 19
Magyar T-Series MGTF Dark Red Engine Paint MG 7
K engine paint Austin Healey 5
S engine paint help Austin Healey 2
TomMull Engine Paint Triumph 6
A question about media blasting and engine paint. Austin Healey 14
BOBBYR Por-15 engine paint Austin Healey 7
M Engine Paint Austin Healey 4
J Engine component paint Austin Healey 3
J Body/Engine Paint codes....? Austin Healey 6
PAUL161 T-Series Engine Paint for a TF? MG 10
chrpark engine paint Spridgets 16
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
M Poor Dupli-Color engine enamel paint results Triumph 13
lbc_newbie Engine paint color....conundrum Spridgets 35
B Engine Prep for Paint Austin Healey 2
M Engine Block Paint Triumph 16
N 1964 sprite engine paint color Spridgets 3
Trevor Jessie Engine Paint Spridgets 8
S Mini engine paint color and pics needed British Motor Corp 9
T 1955 100-4 Engine Paint Austin Healey 8
R Engine paint Triumph 19
JeffS looking for PPG engine green paint code.... HELP! Austin Healey 9
M 1275 Engine Paint Schemes? Spridgets 7
B Question on paint typs for engine parts? Restoration & Tools 16
glemon Moss Engine Paint Application Austin Healey 5
B "Original" Healey engine paint? Austin Healey 10
R BN1 engine paint Austin Healey 7
tateboys Why paint engine compartment black MG 33
C Engine Compartment Paint - Do-Over!! Triumph 6
C I finished paint the engine compartment tonight!!! Triumph 7
S Frame and Engine Compartment Paint Austin Healey 7
F Engine Paint...powder coating or just high temp? Triumph 7
MadRiver Engine color and paint? Triumph 15
A Spitfire 78 Spit - Correct engine/suspension paint? Triumph 4
W Morris Green Engine Paint Code Spridgets 4
jlaird Per previous discussion on engine paint Spridgets 0
S TR2/3/3A $10 in spray paint vs. TR3's engine bay Triumph 10
M Engine Bay and Rattle Can Paint Triumph 9
KLUTZ Brush paint for engine bay? Triumph 15
fmichaels engine paint Spridgets 10
