Dielectric or Conductive grease?
Foghat73
I'm fixing to clean and inspect all my electrical wiring contacts, or as many as I can find, and was wondering which should I use?
Dielectric! It's made just for electrical connections. It's not that expensive and one container will last forever.
As stated above, use dielectric grease.
If you use conductive grease on bulbs... you'll short out the center contact to the lamp base. If you use conductive grease on the bullet connectors, there's always the possibility that it will ooze out and short to ground.
Doug beat me to it. Save the "CopperShield" et al for battery terminals.
You can buy this stuff anywhere - they use it to thermally connect modern ignition modules to the distributor bodies. Without it, the modules burn out pretty swiftly - I suspect that some unprincipalled garages omit it through intention rather than ignorance so they can sell you a new module every 6 months.
It doesn't really matter how much you use (in bulb sockets) as long as it enought to exclude water - but there is no point in wasting it or having it smeared all over the place.
Can get small tubes of it at your friendly car mart part place.
I never put anything back together without a little dielectric grease on the connections and when you need to take them apart it is sooo goood!
Amen, brother! /bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
Nothin' worse than having a corroded bulb break away in your hand on YOUR OWN car!
Peroxide and a good dressing. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Plain Old Vaseline is used by many. I guess the notion is that the metal contacting metal still handles the conduction of electrons, but the goop prevents moisture from interfering with it.
that said, I paid a fist full ($40 or so) for a large tube of dielectric grease. I use it in spark plug boots, dist cap boots, etc.
tahoe healey dielectric grease Austin Healey 13
M Dielectric grease Triumph 6
JPSmit Dielectric Grease alternative Restoration & Tools 7
Tinkerman Dielectric Grease Triumph 21
T Dielectric Grease Triumph 4
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Plugged Grease Zerks Spridgets 7
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
