TR2/3/3A Grease Zerks
CI_TR3
Member
Working on greasing my TR3 and I cannot get grease into many of my zerks. Is there a method to unclog them or do you just replace them. Thanks!
Just replace, IMO. Sometimes you can remove and clean and reuse, but its hardly worth the effort.
Be careful to replace the zerks with the same type -- right angle and such. Otherwise you may not be able to get the grease gun to them.
Charley
The failure to get grease into the fitting is not always the fault of the zerks fault. Sometimes the part you are trying to grease is plugged up with dried up grease and rust. Could take the zerk out and try to shoot some grease through it.
David
S Plugged Grease Zerks Spridgets 7
M Grease Gun and Zerks Triumph 11
N Grease zerks for rack and trunnion Triumph 9
J Grease zerks MG 2
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
brohawk TR6 Grease on rear hubs Triumph 8
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
