Datsun 5-speed info neede
shadowfever
My Arkley MG had a Rivergate/Datsun 5-speed transmission installed before I bought it. I love the difference it makes on the road. I’m not sure though how to check the transmission fluid. I know the original rib cage had an access on the driver’s side of the tunnel. Can anyone tell me how to check it on the Datsun 210 transmission in a Midget? Thanks.
Underneath, left side of the transmission there is a fill plug (square end). Remove that and check the level. It should be full enough to just drip out the filler hole. Put a finger in there and you should be able to feel the level.
Filler plug on the left side of the case.
Beat me to it, Drew! 👍
EDIT: In mid-post was interrupted by a call from a friend.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
T Pressure plate failure on BE with Datsun 5 speed Spridgets 8
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Rut Datsun 5 speed Spridgets 24
T Shifter Cupola for Datsun 5 speed Spridgets 19
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
T datsun 5 speed locking up - circlip problems?? Spridgets 0
abarth69 Innocenti C Datsun 5 speed install Spridgets 21
T Datsun 5 speed locked up Spridgets 7
RickB 65 Midget on craiglist Seattle - 'comes with datsun 5 speed' [nfi] Spridgets 12
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
AN5Sprite Another Datsun 5 speed for sale! Spridgets 8
RickB Fresh Datsun 5 speed and assiciated goodies Spridgets 15
J Datsun 5 speed swap clutch issues Austin Healey 3
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
RickB Datsun 5 speed on Seattle craigslist Spridgets 0
B Datsun 210 5-speed [NFI] Spridgets 5
Rut Datsun yoke for 5 speed Spridgets 26
B Datsun 210 5-speed [NFI] Spridgets 0
PAUL161 Datsun 5 speed transmission MG 10
B Datsun 5-speed trans for sale in Los Angeles Spridgets 4
64rocksprite Datsun 5 speed bronze shifter bushings Spridgets 3
RickB Datsun 210 motor and 5 speed Spridgets 6
jhorton3 Rebuild 5-Speed Datsun Transmission Spridgets 19
B How to identify a Datsun 210 5-speed transmission Spridgets 1
RickB Datsun A14 and Dogleg 5 speed Spridgets 4
Pythias Clutch Throw? Datsun 5 speed. Spridgets 9
RickB Datsun with 5 speed on CL - north of Seattle Spridgets 24
T Datsun 5 speed woes....................help Spridgets 19
Rut Datsun 5 speed Spridgets 4
Pythias Royal Purple in a Datsun 5 speed. Spridgets 6
apbos Speedwell/5 speed datsun/71 mg midget $650 Spridgets 7
RickB Datsun 210 with 5 speed on Seattle CL $500 Spridgets 19
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
Gerard Datsun 5 speed part needed Other British Cars 0
Gerard Datsun 5 speed part needed Spridgets 1
L What does it cost to ship a Datsun 5-Speed? Spridgets 7
bill_powell High Torque Starter & Datsun 5-Speed Spridgets 3
G Datsun 210 5 speed disassembly Spridgets 23
AngliaGT 5 Speed Datsun Transmission Spridgets 8
v8mgbal datsun 5 speed Spridgets 30
RickB Orlando CL - Datsun 210 with 1500 & 5 speed +weber Spridgets 4
