Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
How come every nut and bolt on a Spridget is standard while Front Bleeder Scews are 11 mm and rears are 7 mm? At least they are that size on Bugsy my '68 Sprite..
Mine were metric in the front and standard in the back. I think it depends on where you bought the bleeder screws. Maybe the ones that seem metric are actually a whit-worth size? I just finished my front end. One of the grease zerks was not metric or standard.
After I wrote that note the name Whitworth came to mind. The bleeder screws are original to the best of my knowledge. I know there is at least one more Whitworth fitting on a Spridget somewhere as I recall but don't know where to find it. 7 mm works on the back of Bugsy and I've got the front soaking as DS wanted me to struggle a bit. Time for the PB Blaster to do its thing.
7/16" = 11.1 mm. Those wrenches are effectively interchangeable.
I just double checked the bleed screws on the calipers I have on my bench and both those wrenches fit with very similar amounts of play.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
