Tonneau conundrum
IanIrving
I've just fitted a new tonneau to my BJ8 bought from AH Spares. It fits well and wasn't difficult to do unaided but I have a couple of questions. There are four flaps on the top, two short ones are covering slots where the seatbelts pass through when used as a half tonneau The other two, forward of the short flaps and about three times as long running across the car seem to have no aparent purpose. My questions are these.
1) Does anyone know what those longer flaps are for?
2) In the Clausager book, page 79, only the short flaps are shown as having snap fasteners whilst in the Haynes book, page 144, all four flaps have snaps. Which is correct.
3) The short side flap which runs across the top of the door to the lift the dot pin just behind the quarter light start from underneath the panel which runs around the rear to the tenax fastener just behind the door. Do they fasten in some way to that tenax pin or are they just tucked in? Clausanger book shows them looking just tucked in whilst Haynes book (Great cars, Austin Healey) Looks much more like they are fastened in some way.
Hope that is all clear and someone has the answers, maybe Randy has some photos!
Thanks
Ian
Ed_K
Hello Ian,
Those flaps are to allow the tonneau to be snapped down to the
front surface of the rear seating area. You should have two studs on each side, ( 2 behind the passenger seat and 2 more behind the driver's seat). This is so you can have the tonneau installed while you alone or you and a passenger are riding in the car. The tonneau folds over the support bar and then snaps down to the front surface of the rear seating area when it is open.
I will try to post a picture but may not get to it for a while.
Ed
gra
Member
Agree with above. The door side panel goes on the same stud as the panel with the fastener behind the door. The door panel portion goes on first. You need a hole in the door panel and can fit a plastic ring into the fabric or just make a hole and stitch around it. You then place the door panel with the hole on the stud first and then short panel with the regular fastener.
You can also tuck it under and it looks ok.
I
IanIrving
Thanks for the instant answers, that all makes great sense except maybe I'll have to lengthen the tenax stud behind the door if both thicknesses of tonneau are to fit over it. I tried today with that configuration but couldn't get the tenax to stay on with both pieces of fabric there. I'll look for the other snap studs on the rear seat fronts.
Thanks to all
Ian
gra
Member
Re: Tonneau conundrum Pics
I have taken some pics of the flap with fasteners that you asked about as well as the side panels and how they fasten but for the life of me I am unable to attach to this message. If you pm or email me I will send to you. George
If you do use the seat belt flap provided you will need to have the detachable belts that Moss sells. The work nice.
I
IanIrving
Hi NIB
I chose the Vinyl in black, the other option was mohair but the top and the cover which came with the car are both black vinyl so I thought it best to stay with that. I was very happy with the quality of the cover from AH Spares, no connection with them, just a satisfied customer. I hadn't realised until it came that the fittings were supplied but not installed to had to do the fitting myself but not at all difficult. Starting from scratch took me about three hours with nothing more than a piece of chalk, a bradawl, a couple of sharp cutters andpliers to bend the tabs on the "lift the dot" fittings.
I have detachable seart belts so all good there if a bit of a fiddle given how close the fittings are to the seat bases but there is just enough room to get them in an out ok.
Thanks for all the help and for your photos George.
Ian
Ed_K
Here are some pictures
Doghouse
It may seem obvious to some, but could you post a picture of how the support rib installs? I am a new owner and I can not figure out where the curved ends go!
bob hughes
Hi Doghouse
No picture, but if you have a BJ7 or BJ8 then there should be a socket on each side of the car, to receive the support bar just in front of the hood frame mounting bracket on each rear wing.
Bob
Doghouse
OK, here is my issue, I see the socket, but the support bar just does not reach. The main upright of the top is blocking insertion of the rail into the socket. The support rail is about 1/2 - 3/4 of an inch too short. Do I have the wrong bar? Should I just do a little creative bending? should I just get a short piece of AL bar and make a little insert / spacer? :confuse:
CW
The width is adjustable with the sliding of the two tubes. The height is not. They should all be the same. You want it to be as low as possible and it should be attached at the flaps to the wall below the rear seats. If you fuss with the height it will not attach at the wall or the dash. You could also stress the fit to the tennex on the chrome door pieces. You want to do this when it is in the sun and stress it when cold for a nice smooth look.
I
IanIrving
Finally received parts and installed the snaps under the rear seat to hold down the big tonneau flaps as per the photos. I checked the panels but no sign there were ever snaps fitted before, no holes for them anywhere. Does that mean they were only ever there on BJ8s supplied with tonneau ex factory. My Heritage certificate does not show tonneau so maybe it never had one before.
Ian
Popeye TR4/4A Tonneau or top cover? Triumph 12
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
Popeye TR4/4A Tonneau snaps by windscreen Triumph 2
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
Celtic 77 Wanted Tonneau MG Classifieds 4
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
pbraun Bugeye tonneau pattern Spridgets 1
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
Upland Tonneau cover repair Spridgets 2
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
jackq MGB New tonneau cover in box MG 1
T supporting BE tonneau cover during heavy rains Spridgets 10
A TR2/3/3A Pegs-top and tonneau Triumph 3
L Wanted WTB: Bugeye tonneau cover with roll bar cutouts Spridgets Classified 0
I For Sale TR6 tonneau cover Triumph Classifieds 5
Hangtown Healey BJ8 tonneau cover bag Austin Healey 6
T Securing the Tonneau on a 3000 MkII Austin Healey 4
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
J Wanted WTB: TR3a top and Tonneau Triumph Classifieds 2
CessnaTPA Tonneau Install Question Austin Healey 13
H Tonneau cover Austin Healey 2
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
K For Sale TR4A tonneau cover.... Triumph Classifieds 3
Keith_M bugeye tonneau fittings Spridgets 11
K TR2/3/3A Tonneau capping mounting questions.... Triumph 2
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
K TR2/3/3A Rear tonneau capping plates and bridge pieces for mounting the Hardtop? Triumph 3
vette BJ7 Tonneau Cover Austin Healey 10
RickB MGB Any deals for a new Tonneau cover? MG 8
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
G General TR What type of car is this tonneau cover for? Triumph 5
6 Tonneau bar color Spridgets 6
T TR2/3/3A Tonneau cover snap install Triumph 14
AUSMHLY Who makes a good tonneau cover for a 100-6 Austin Healey 6
K TR2/3/3A Restoring a tonneau cover? Triumph 3
Sarastro General Tech Tonneau cover vinyl restoration MG 5
mrv8q TR6 TR6 Tonneau Q Triumph 3
G Snap locations for BJ8 tonneau Austin Healey 10
Jeepster BJ8 tonneau cover Austin Healey 8
TR4A_IRS TR4/4A Location for dash snaps for tonneau cover? Triumph 3
Jim_Gruber Tonneau Rail for a BE Spridgets 16
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
D Tonneau Cover Questions Spridgets 25
