Clutch Release Bearing
middleagecrazy
Does anyone know of a replacement release bearing for the 1275's with the ribcase transmission. I replaced the clutch pressure plate and the release bearing three months ago. That was about eight thousand miles ago. Now the release bearing is screeming. heck will freeze over before I will pull the engine every three months to replace the bearing. Keep in mind this is my daily driver.
Bugeye58
If you want the roller type, try The Winners Circle.
https://www.spridget.com
I think I'd do some investigation and find out the root cause, though. Even the carbon types seem to last forever on all of mine, and I've got a bunch! Make sure the throwout arm is releasing all the way, and not letting the bearing rest on the pressure plate fingers all the time. An incorrect length clutch pushrod can cause that to happen.
Jeff
bugimike
One solution (though not for purists!) is to add a "return spring" to the fork! This will pull the bearing away from the plate to keep it from riding and wearing!
middleagecrazy
middleagecrazy
Thanks for the replys. All the parts were NEW stock parts from VB. The slave cylinder has had no modifications done to it. Stock shaft. I drove the wifes Jag today and plan on checking the Sprite tonight. If I do have to pull the engine to replace it I'll check out Winners Circle. Its like you Mike said these things normally last 4ever the last bearing had eighty thousand miles on it. That I know of. I don't know how many were put on it before I got the car.
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
B Clutch Release Bearing Austin Healey 2
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
B MGA Clutch release bearing MG 4
C Clutch Release Bearing Austin Healey 5
T Clutch release bearing question Spridgets 10
Xte New clutch release bearing completely detroyed ... Austin Healey 4
K TR2/3/3A Clutch Release Bearing Triumph 4
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
K TR2/3/3A What's the easiest way to remove the clutch release bearing from the bronze sleeve? Triumph 7
K TR4/4A TR4A Clutch Release bearing Triumph 6
abarth69 1275 Clutch release bearing Spridgets 18
mountainman TR2/3/3A TR3 Clutch Release bearing Triumph 2
Thor 1500 clutch release bearing removal -how to do it? Spridgets 4
M TR2/3/3A TR3 clutch release bearing Triumph 3
T Clutch release bearing.... Spridgets 14
R6MGS T-Series Clutch Release Bearing MG 5
K Missing spring clutch release lever Other British Classifieds 1
W General Tech Clutch Release Question Triumph 6
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
O sprite clutch release Spridgets 1
S TR2/3/3A TR-3 clutch pressure wouldn't release Triumph 3
drooartz Clutch release lever bushing Spridgets 12
D T-Series MGB GT Clutch Won't Release MG 5
T Slow clutch release Spridgets 6
martx-5 Gearbox Clutch Release Fork Triumph 2
Lutz Kramer Clutch is disengaging slowly Austin Healey 13
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
