Carburator 50 Prefect 1172cc engine 10hp
algot1901
Bronze
I am struggling to put together the carb it is a Ford Carb and the kit I received seems to be missing one gasket for sure and possibly two. Where the bowl and body meet should there be a gasket between the surfaces and what is called the emulsifier should there be a gasket to go between the bowl and the body, looking at the repair manual it shows all of the parts in the blowup minus the gaskets.
is it something you can pop up a picture of? or alternately make your own?
Much on the interweb about the hammer method
First are you sure it is a Ford carb and not a Zenith? There is a gasket between the bowl and body. You may be able to get a kit from Kip Motor or Small Ford Spares.
From the small spares, there is only one gasket which is between the venturi plate and bowl, the gas should only get to the halfway mark on the bowl. Seems kind of dangerous as the carby sits on top of the exhaust manifold so that means I can install the carby oh engine and tranny are in the car.
K TR2/3/3A TR-3B carburator issues Triumph 2
AngliaGT MGB-GT SU Carburator Linkage - MG 9
glemon Carburator Contentment Ahhh! Triumph 1
J TR2/3/3A carburator decisions for TR3A Triumph 48
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bcbug Replacing carburator on Midget Spridgets 16
J Carburator draining Triumph 3
R carburator issue Triumph 1
J Zenith Stromburg 175 carburator tune? Other British Cars 3
P Cleaning carburator air filters Austin Healey 2
S Backfire through rear carburator Austin Healey 18
R Gas leaking from the carburator - help Triumph 8
T Gas running from carburator tube?? MG 1
Bayless New Prefect progress Other British Cars 7
Bayless The Prefect Grille Other British Cars 0
Bayless More Prefect Progress Other British Cars 2
algot1901 50 Prefect wood roof support / bow Other British Cars 8
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 1950 Prefect starter Other British Cars 1
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
algot1901 1950 Prefect Ign Switch Other British Cars 1
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 1950 Prefect Speedo Cable Other British Cars 8
algot1901 Brakes for Anglia / Prefect Other British Cars 2
Bayless My Prefect update Other British Cars 5
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
algot1901 1950 Prefect Starter Other British Cars 10
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
algot1901 1950 Prefect Headliner Other British Cars 17
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Bayless Even more progress - the Prefect Other British Cars 5
L !953 Ford 4 door Prefect Other British Cars 3
A Body Paint Codes for 1950 Prefect E493A Other British Cars 1
A Rubber parts for 1950 Prefect E493A Other British Cars 6
A 1950 Ford Prefect Windows Other British Cars 4
A 1950 Prefect Vacuum Tank Other British Cars 22
A 1950 Ford Prefect Floor Covering Other British Cars 2
KLUTZ Wow.. A Perfect Prefect ....... Other British Cars 2
A 1949 - 1952 Ford Prefect Other British Cars 9
