50 Prefect wood roof support / bow
algot1901
Bronze
I am in need of one top wood bow for a 50 Prefect or a drawing of the radius. mine are all bent from my Dad putting stuff on the roof this is a long shot but if you have a good one either do a trace or could I borrow one to make a copy I will pay for the postage both ways, let me know.
Jim
Bayless
Jim, do you need a full size drawing or can you work from a smaller one with lots of measurements? I think I can do either but it may take a couple of days since they are installed.
algot1901
algot1901
Bronze
Whichever is easier, right now I have a big hole and some really funky bows yup no problem is there anyway I can get you my address with out the worl knowing?
JPSmit
send a PM - hover your 'mouse' over Bayless's name and a screen will open that allows you to start a conversation
Bayless
Hey Jim, I was able to measure the bow today. This was not trivial to do in the car but here is what I got. Center to center of the mounting bolt holes I got 32 inches. I set up a straight edge from end to end at the bolt holes. I then measured the distance from the straight edge to the bottom of the bow every 4 inches from one end across to the other end. The measurements are:
end: 0"
4": 3/16"
8": 3/8"
12": 1/2"
16": 9/16"
20": 1/2"
24": 3/8"
28": 3/16"
end: 0"
Let me know how this works out for you.
algot1901
algot1901
Bronze
Which bow did you measure (do not mean to be picky) #1 is the first from front to back. What I did not realize is that they are all different lengths, would you mind measuring the others?
The way you measured will work just super
Thank you
Bayless
I measured #2. I can't get back to the shop for a while now due to minor surgery. One of my shop partners tried to measure the lengths for me today. He got 31 on # and gradually increasing to 33 on the last one. It's hard to do that precisely in the car but I think all will be within 1/8 inch or so. Interestingly, I always remembered them as all the same length but it has bee a long time since I had them out. I feel sure the curve from #2 will work for all anyway. Just make #2 then mark the others from the center out.
algot1901
algot1901
Bronze
If I take the one you did and just use the center measurement I am thinking (here comes trouble) they will all look ok. you get well and again I thank you sir,
Bayless New Prefect progress Other British Cars 4
Bayless The Prefect Grille Other British Cars 0
Bayless More Prefect Progress Other British Cars 2
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 1950 Prefect starter Other British Cars 1
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
algot1901 1950 Prefect Ign Switch Other British Cars 1
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 1950 Prefect Speedo Cable Other British Cars 8
algot1901 Brakes for Anglia / Prefect Other British Cars 2
Bayless My Prefect update Other British Cars 5
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
algot1901 Carburator 50 Prefect 1172cc engine 10hp Other British Cars 4
algot1901 1950 Prefect Starter Other British Cars 10
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
algot1901 1950 Prefect Headliner Other British Cars 17
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Bayless Even more progress - the Prefect Other British Cars 5
L !953 Ford 4 door Prefect Other British Cars 3
A Body Paint Codes for 1950 Prefect E493A Other British Cars 1
A Rubber parts for 1950 Prefect E493A Other British Cars 6
A 1950 Ford Prefect Windows Other British Cars 4
A 1950 Prefect Vacuum Tank Other British Cars 22
A 1950 Ford Prefect Floor Covering Other British Cars 2
KLUTZ Wow.. A Perfect Prefect ....... Other British Cars 2
A 1949 - 1952 Ford Prefect Other British Cars 9
JohnGone MGB Wood Dashboard Kits MG 1
NutmegCT "French polishing" lacquered wood? Restoration & Tools 9
B Wood Braces, Hardtop Austin Healey 3
NutmegCT Exterior wood finish Restoration & Tools 21
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
L Replacing veneer on wood dashboard Restoration & Tools 14
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
Rut TR4/4A TR4 wood dash Triumph 26
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
R Wanted wood steering wheel Jaguar Classifieds 0
S TR2/3/3A wood next to the door on a tr3 Triumph 4
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Gliderman8 General TR Wood rimmed steering wheels Triumph 20
J TR2/3/3A Mystery Wood Triumph 7
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
KVH TR4/4A Refinish Wood Dash Triumph 7
P BN2 new wood steering wheel install Austin Healey 5
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
TomMull TR2/3/3A door wood Triumph 36
