General Tech Camshaft Breakin
KVH
I finally got my TR4A back together. Eight months of waiting and finding the time, ordering parts. What a great sound when it started back up.
I did the 30 minute 2500 rpm routine. Can I drive for about 1000 miles on that oil with ZDDP additive, and the camshaft paste still in the engine and sump, or must I immediately dump it all out and change the oil?
I read conflicting bits of advice on that topic. thx
number6
I think you are safe for a couple of hundred miles or so. When I rebuilt the Rover I went 200-300 then changed again at 500 and last at 1000. Then started following the manual.
I think you will find a lot of differing opinions on this, but it is also important to let things bed in, so I would not use any additives in the beginning other than the ZDDP.
poolboy
You're probably going to have some break-in "debris" in the filter and oil,,that you may want to get out of circulation fairly soon.
D Stock Camshaft TVR 0
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
nichola TR6 GP3 Camshaft won't turn Triumph 8
BN6 Healey 3000 Camshaft Identification Austin Healey 4
A Camshaft Austin Healey 0
R Woodruff key for DWR camshaft? Austin Healey 2
Sarastro TR4/4A Camshaft oddity has me concerned Triumph 6
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
KVH General Tech New Camshaft Has Rust Triumph 7
rjhco For Sale Camshaft lifters - tappets - followers Triumph Classifieds 0
E TR6 General Inquiries.....Camshaft and valve clearances Triumph 3
Rut 1275 oil pump, camshaft adapter Spridgets 2
KVH General TR Torque for the Camshaft Bolts Triumph 3
KVH TR4/4A Is this Camshaft OK? Triumph 7
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
T TR2/3/3A Camshaft Recommendation Triumph 13
B BJ8 Camshaft Question Austin Healey 3
B Camshaft choices Austin Healey 11
T TR2/3/3A Degree Reground Camshaft Triumph 2
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
T TR2/3/3A Camshaft Front Bearing Bolts Triumph 3
T TR2/3/3A Camshaft Questoin Triumph 2
T MGB MGB Camshaft MG 1
H TR6 TR6 camshaft options Triumph 9
DornTRoriginal Is the sprocket on the camshaft supose to fit so bloody tight? Triumph 4
L 1275 Compression, Camshaft, et al Spridgets 16
S TR4/4A TR4A camshaft recomendation Triumph 6
B Camshaft specification, what have I got? Austin Healey 15
M BJ7 29F Eng Camshaft Info Austin Healey 1
dklawson Camshaft - Degreeing w/o Pulley Marks Triumph 17
N Camshaft query???? Spridgets 9
M Tri Carb Camshaft Austin Healey 4
B Camshaft bearings MG 6
nissanite Lifter & Camshaft relationship Triumph 5
PATR8 Camshaft bearings replacement Triumph 5
T 100/4 Camshaft Austin Healey 1
N Check camshaft type Austin Healey 28
I camshaft and camshaft bearing information please Triumph 1
D Camshaft Austin Healey 19
PatGalvin TR2/3/3A Camshaft/Crank alignment on TR3 Triumph 5
Tr4dude TR4/4A any idea on this Tr4 camshaft? Triumph 3
PatGalvin New Camshaft - Any BCF Members Interested? Triumph 2
doughairfield Timing chain sprocket to camshaft Triumph 9
A Spitfire Spitfire 1300 camshaft dimensions Triumph 7
Stinger TR4/4A Need TR4A Camshaft Bearing Setscrew Help Triumph 5
P Camshaft Questions Triumph 10
Sarastro Camshaft installation/end float problem Spridgets 16
