T-Series bypass hazard switch
Run a jumper between the two green wires at the plug. I think it's the green ones - someone verify me.
thanks,i'm trying to get signals working on my 78,when i bypass the hazard switch the signals light up on the dash and i get a clicking noise from the box on the passangers side,should there be two switches there?the round flasher unit doesn't seem to get any power.
Make yourself an enlarged copy of the section of the wiring diagram that shows the turn signal circuit. For me I have found enlarging the drawing 150% makes it easier to read the color coding for the wires. To print I click current view in the print range when the printer dialog box opens.
After looking at the wiring diagram it will become obvious wich wires are the power inputs and wich wires are the power outputs.
are you running the original electronic ignition system?
ok got signals working,connections where on wrong on relay switch,the only thing is when i turn on lights and then turn on passenger signal the lights will not flash on that side but they are fine on the drivers side.could this be a wire prob.or low voltage.cheers
Also, keep in mind, the side marker lights are just marker lights... they don't turn on and off with the signals... I made that mistake for a little while until I studied a wiring diagram.
I agree with Kimberly...sounds like bad grounds, but you should also check the flasher unit...a couple of bucks for a new one might help...or at least you will have a spare when you need it.
If everything is connected properly and the turn signals flash on one side then there is nothing wrong with the flasher. The power output of the flasher goes to the turn signal switch. It cannot only affect one side.
Also, the bulb sockets can get pretty nasty too... clean with a nice small wire brush, and lubricate with a nice dielectric grease.
My DPO had disconnected the flasher unit, the hazard switch and so on. Now I hanaged to get the turns working on one side so what you are saying is that the reason the other side in not working is between the turn signal switch and the bulbs?
A volt meter, or even one of those cheap light probes would come in handy finding where the power is stopping.
I have a mess of orphan bullet connectors in the engine compartment roughly above the dizzy so thats got to be a good place to start.
thanks for all the info,got it working now,ground wire was off on front signal,still got some hair left.lol
Back when I only had a couple of MG's (WOW! How long ago was that?) one of the things I incorporated into my maintenance was cleaning all the bullet connectors...each quarter I tackled a different part of the car - engine compartment one quarter, inside car another, under car/in trunk a third - never had electrical problems during those years!
Doug Sabbag TR6 Ammeter blown.. bypass? Triumph 10
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
M TR5/TR250 Bypass valve Triumph 28
A T-Series MGTD oil pump bypass valve MG 0
Gliderman8 TR6 Rheostat bypass Triumph 1
S TR6 Stromberg Bypass Valves - Question Triumph 11
R TR2/3/3A Thermostat and bypass hose Triumph 15
C TR6 Seat belt warning bypass for new harness. Triumph 6
L TR6 Bypass valve adjustment Triumph 1
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A bypass hose Triumph 11
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
sundown TR6 1973 TR6 bypass valve Triumph 1
P 1275 bypass hose???? Spridgets 5
L TR2/3/3A bypass hose Triumph 3
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
D Overdrive bypass switch Austin Healey 1
K TR2/3/3A Paging TR3driver re blocked bypass and Shaller pdf Triumph 1
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
E 1275 Water bypass nipple Spridgets 11
V ZS Carb Bypass Done Triumph 1
V TR6 TR6 ZS Bypass kit Triumph 18
wangdango TR6 '76 TR 6 stromberg bypass valve? Triumph 1
R Bypass hose... Spridgets 7
19_again Gas bypass-low rpm's MG 5
A bypass vs no bypass Spridgets 10
E 1275 Cylinder Head Bypass Nipple Spridgets 4
Paulus Stromberg bypass issues Triumph 4
K TR2/3/3A TR3 Cooling...Blocking the Bypass Triumph 5
jerrybny Bypass Valve Assembly Triumph 2
Y Oil pressure ignition bypass MG 3
J TR4/4A TR3, TR4 bypass hose needed , NAPA #? Triumph 2
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
SherpaPilot TR6 Hazard Switch Problem Triumph 8
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
Got_All_4 Wedge Hazard siginals don't work!! Triumph 4
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
tinman58 TR5/TR250 Hazard switch $189.00? Triumph 10
B MGB 79B hazard line fuse MG 1
T TR2/3/3A Hazard::TR3 bonnet stayrod assembly crack Triumph 1
JFS Wedge TR8 Hazard Flasher Triumph 15
F TR6 76 TR6 Hazard Switch Triumph 1
A Wedge TR7 Hazard Light Switch Triumph 1
R TR5/TR250 TR250 Hazard Switch Triumph 8
Jim_Newman Hazard warning lights Austin Healey 1
Woodie TR6 tr6 76 hazard flasher...not Triumph 8
L TR2/3/3A Hazard Flashers for TR3A Triumph 4
Mickey Richaud T-Series Hazard/Rear Window Defogger Switch MG 7
hondo402000 TR6 hazard flasher unit for 69 70 71 TR6 model Triumph 22
hondo402000 Hazard relay and hazard flasher question Triumph 9
