Bugeye decal placement help
ichthos
I bought one of those decal kits from Moss, and I am busy trying to figure out where they go. Can someone tell me how many decals go on the washer bottle and give me the measurements on where they (it) goes? Thanks, Kevin
Decals on washer bottle, I think not. was silk screaned on.
That is the best I can do for now, Jack. Can you give me measurements on how many there are and the placement in inches or centimeters?
Kevin
W Bugeye Tudor Wash Bottle Decal Spridgets 0
B Is the rear edge of the Bugeye bonnet sheet metal supposed to be bent inward? Spridgets 2
Todd78d Normal Bugeye Running Temperature Austin Healey 1
Ohiobugeye Can a Bugeye ignition switch be replaced with a universal ignition switch ? If so how would the wires be attached ? Spridgets 15
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
