jjbunn
The TR6 brake master cylinder reservoir has two compartments. One at the rear, one at the front. Are these interconnected? How is one supposed to top up the front compartment: the opening is very small?
The front compartment on my leaking master was completely empty, and dry. It doesn't look as if there has been any fluid in there for a long time. Sure enough, when I removed the PDWA it also was dry as a bone on that circuit.
I thought I understood these systems, having worked on the MGB's! Another puzzlement: there is only one wire that attaches to the PDWA switch from the harness. I was expecting a pigtail, like in the MGB. I'm getting confused.
