TR2/3/3A Boot Seal Pics
CJD
I could use some pictures of how you guys have done the seal for the boot lid on the early cars. I know this has come up before...but now I'm having second thoughts after studying the seal rail layout from the TR2 up to the 60k TR3.
thanks!
TexasKnucklehead
OK, here's what I did on my 59. This picture was taken before I glued it -as you can see the right corner is loose. Once glued into the channel, the rubber tore from the right and left hinge studs. Before I glued it, it continually popped out. It keeps water out fine, but has two semicircular matching cuts. I think if the lip was facing inward, it would still be cut by the nuts on the hing studs. -I'm sure you will find a better way, but mine isn't broken at the moment...
Let me know if I can provide a better picture.
TR4nut
John - I didn't do it so don't know how hard it is but the best I've seen for the early channel style seal is if you can miter the corner and Re-glue the miters.
CJD
CJD
Wow...you guys brought up exactly what was concerning me!
On the TR3A the seal channel was rounded, so it made sense to angle the seal outward, and that worked great. The hinge nuts on the early lid almost preclude angling the seal outward, as they will clip the seal and almost definitely tear it.
Then...with the seal angled inward, the sharp corners become and issue! When the seal is turned inward, rounding a sharp corner bunches the seal lip so it sticks straight upward...lifting the deck lid with it. If you angle outward, then the seal lip sits better, but you are back to the close hinge nuts again.
I am leaning towards seal inward to clear the hinges...and mitered corners to help it lay properly.
Thanks for the inputs! I was hoping someone had tried the mitered corner technique and had a pic.
TexasKnucklehead
Another option might be to cut the studs a little shorter, and use thinner nuts on the inside? (Sometimes size does matter.) -Maybe skip the lock washer too.
TR4nut
Ask and you shall receive! Lousy pics of a car I used to have. I am not positive but pretty sure the old seal was mitered already.
TexasKnucklehead
Randy,
Quit looking for dirty pictures and get that TR6 ready for the club drive tomorrow.
Even those pictures look like the seal is torn (or cut) at the hinge, and the lip looks to be pointed outward.
CJD
CJD
Yep...either that is a VERY nice miter job or the seals may have been offered that way in the past. It does look turned outward. I think I'll try to miter it. I'll have to play with the lip direction and hinge options to see which works.
Thanks again!
mgedit
Here are a couple of how I did mine. Trying to recall whether I had to trim the seal a bit or not, but I think I did. Also thought I had more pictures!
Can take more pictures after car is out of storage, but that may be a few more weeks as we just got another 5 inches of snow yesterday.
Cheers, Mike
2liter4cyl
Bronze
This search for a proper boot seal came up 2 years ago and my experience then was like now. With the gas tank yet to be installed, I was able to view the fit up of the seal. With the lip outward, a first best choice, the fit was BAD. Pressure points and many gaps. The lip inward was much better. I then measured the gaps and stress points for location and amounts. For this I made extensions of the flange and cut away high spots. I could then see a great fit! Having said all of this, I suspect the flange was a random height meant for spot welding. The lip outward may have been better with a better flange. I have a TR3A comm. # TS75773L 1960. Le T.
CJD
CJD
Thanks Mike and Le T!
As I study more and more pictures, seal out is predominantly what everyone is doing. Also, 100% of the cars with seal outward show gouges in the seal from the hinge nuts! I can see why Standard changed the seal design post 60k, as the sharp corners just do not fit well. T, your work with modifying the flange is likely the way to go...but I wish I had known this was an issue before the paint went on the car. Oh well.
CJD
CJD
I played with the seal for a couple hours today. I have come to the conclusion that there is no good way to mount it.
If you go lip out...the hinge nuts will gouge it, and it rubs on the deck lid about 3 inches in from the top sides.
If you go lip inward, it clears the hinge nuts, but then it hits the 3 latch asssemblies at the bottom, and still gets gouged.
It's basically a loose/loose design. I see why they redesigned it for the 60k up cars.
Don Elliott
In 1990, during the restoration of my early TR3A, I saved the original seal for the trunk lid and put in new seals as they had been originally.
There is a long piece which goes down one side - then turns the corner, the goeas up the other side. The seal flares towards the outside and there are no cuts or mitres in the lower corners.
There is a second piece cut to fit all across the top. This is angled inwards towards the trunk opening so as to not interfere with the hinges of the securing studs.
Originally, both seal pieces had been glued down into the channel that supports the seal pieces. But in 1990, I cut the pieces a bit longer than needed in case some schrinkage occurred later. I have run it like this for the next 112,000 miles with these seals not glued in. It has neven leaked and when I want to clean out the boot and this channel area, I just pull out the seal pieces, clean it and then put the seals back into place.
Don Elliott, Original Owner, 1958 TR3A
CJD
CJD
Don, that solves all the problems! I never would have guessed that the factory had the seal change orientation, but doing that makes everything work out. Glad I waited to install it...thanks!
CJD
CJD
Yeah, Don is great answering originality questions! I had thought about reversing the seal, but discarded the idea thinking there is no way that would look original. Turns out the factory had to go through the same thought process, and wound up reversing the seal to solve it too.
TS27952L
Great post from Don - thanks!
He helped me a lot as well.....
Regarding the factory change in the seal type: The old seal needed a channel where it is push into. This required a set (4) angled pieces of sheet metal, they have to be welded to the body parts (and are prone to rust, as this channel has no drainage).
The later seal ist clipped onto the outer section of the former channel: So no need for channels, welding etc.
My assumption was: Saving cost was the motivation for the change (as for some others during the production of the TR3-A-B)
Cheers
Johannes
B Fitting the Boot Lid Seal Austin Healey 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
M TR4/4A Trunk/Boot rubber seal. Triumph 8
mrv8q TR2/3/3A Boot Seal Q Triumph 7
B Boot trunk seal alternative advice ? Austin Healey 15
Got_All_4 TR2/3/3A Is this the proper Boot lid seal? Triumph 9
Jeepster Boot seal Austin Healey 10
J TR2/3/3A Boot lid seal. Triumph 3
Tinkerman TR2/3/3A Boot Lid Seal TR3A Triumph 7
AUSMHLY Boot seal Austin Healey 4
chicken Boot seal Austin Healey 16
dklawson Spitfire Spitfire Boot Seal [Mk4] - Profile? Triumph 2
T TR4/4A 4A Boot [Trunk] Seal Triumph 6
Lin Boot Lid rubber seal Austin Healey 10
B TR2/3/3A TR-3A Boot Seal Installation - Help! Triumph 5
Tinkerman TR2/3/3A Boot Seal, TR-3A Triumph 5
T Boot seal for AH 3000 Austin Healey 12
G Wanted Tr4a boot lid Triumph Classifieds 2
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
AUSMHLY Boot Lid Identification Austin Healey 2
J Restoration Progress - Boot Installed Austin Healey 1
B BJ7 Boot Trim Austin Healey 7
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
chicken Boot Lid Badge Austin Healey 8
F TR2/3/3A Boot floor Triumph 50
steveg TR6 Dealing with Rack Boot Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
T How do you cover your battery in the boot? Austin Healey 5
S Securing the jack with strap in BJ8 boot Austin Healey 11
Michael Oritt Boot floorboard? Austin Healey 9
S Boot Liner - BJ8 Austin Healey 19
C Under boot and under bonnet paint? Austin Healey 7
tahoe healey Leak into boot Austin Healey 17
B TR6 Boot lid thread plates loose in stiffener Triumph 1
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
B Soft Top Boot Cover - BJ7 Austin Healey 5
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
ckeithjordan TR2/3/3A Boot Trim Triumph 3
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
B Dynamat in Boot? Austin Healey 7
S TR4/4A Fascia support and shift rod boot Triumph 0
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
