BJ8 radiator bottom hose
mmgwhite
Member
1967 BJ8
Need to pull the existing original radiator from the car. Bad leak
On first inspection the unfastening of the bottom radiator hose seems to be a near impossibility. Mirror and light shows a hose clamp around the hose
behind/under a sturdy frame cross member. essentially unreachable with clutsy fingers. Not to mention trying to re-attach upon re-assemble.
It would appear that the radiator cannot be "rocked" far enough foreward to help much because of airway deflecting shields in front of the radiator and fan behind.
I have been searching for a how-to thread to no avail
Anybody have an answer as to how to attack the removal/re-installation of the bottom radiator hose??
Other tips before I start??
Thanks in advance.
Mat
Hi Mat, I'm not trying to be smart, there is no trick ya just have to look at it this way, if Man put it together, another Man (you) can take it apart. I know it is a bear to get at, just find the right tool to help. Also after you get the clamp loose, you should be able to push the hose off from the front of the car. Your shields maybe why you have the problem, I don't have those shields.
Just wait till you try to take the carbs off someday! :smile:
If you are removing the radiator anyway, take off the front deflectors. If the hose is going to be replaced, cut it just beyond the lower outlet.
Bob
Did you look to see is the screw was tightened up from the underside? With a reasonably long screwdriver, I can usually get to the clamp from either the top or bottom. If the screwclamp has a hex-head, that opens up the possibility of using a 1/4"-drive socket, and either a long extension or close-quarter ratchet to loosen the clamp.
You can see the clamp between the xmbr and radiator.
Here's a shot taken while I was repairing the swaybar mount, you can see the head of the clamp between the petcock and hose itself.
In the shot above, I was just about to weld in these plates; take that, parking curb!
My hose clip has a hex head and you get at it from below. If yours has a screwdriver slot, it might still be easier from underneath on a 1/4" drive ratchet.
I usually yank the radiator at least once a year to do a valve adjustment (to get access to the dog nut on the crankshaft for turning the engine). I remove the lower hose by removing the bottom radiator attaching screws (two on each side), loosening the screws at the top (one on each side), then swinging the bottom of the radiator forward enough to gain access to the lower hose clamp screw from below (mine has a slotted head)
The sharp corners of the air deflector can gouge the radiator core if you're not careful. To avoid that and to avoid having to remove the deflector when I remove and install the radiator, I made some shields out of scrap aluminum sheet and tuck them into the front side lower corners of the radiator before pulling it up and out. It doesn't simply come out (what does?), but you have to make sure the fan blades are turned to the proper position to clear the bottom hose connection of the radiator as it comes up (I have a Texas Kooler). You'll probably have to shift the rad up and down and back and forth as you try to figure out what's holding it. Probably would be better to have another set of hands to help, but I typically do it alone. Reinstallation is a reverse of removal. Make sure the lower hose clamp screw is oriented so you can get at it next time from below, and don't tighten any of the radiator attach screws until all are in place, as well as the lower hose connected.
Steve, you know...
With all (6) sparkplugs out, and the car in 4th gear, you only have to roll it a few feet to get each cylinder in position to check/adjust the valves. A lot less involved than pulling the radiator__unless you just like doing that...
Steve, you know...
With all (6) sparkplugs out, and the car in 4th gear, you only have to roll it a few feet to get each cylinder in position to check/adjust the valves. A lot less involved than pulling the radiator__unless you justSteve, you know...
OR:
He can be lazy like me and use a remote starter button, ignition off and car in Neutral.----:applause:
Nah, I've tried it that way. I have to do it that way to adjust the valves in my Midget since it has no other way to turn the engine, and I think it's a hassle, although it has 4 less valves to deal with.
I'm too much of an engineer to do it by rolling the rear wheels. I like to see exactly when the valves are transitioning from all the way open to closing.
Anyway, I've done it enough that I can have the radiator out in about 10 minutes, then adjusting the valves is a whiz. I like to go back through the adjusting sequence again just to check to make sure everything is right. I once had a burned valve because I didn't keep a close check on the clearances. That'll make you more careful.
Ten minutes - that is fast.
Is it not possible to disconnect the upper radiator hose and the top end of the lower radiator hose, then remove the bolts holding the radiator, and then raise the radiator up enough for easier access to the lower clamp?
Regarding turning the engine when setting the valves, with the spark plugs out, one can grab the fan blades and turn the engine that way - providing the fan belt is tight enough to do this. I have tried various ways to turn the engine and various sequences for setting the valves. It doesn't hurt to double check the valve settings using several methods.
Steve !!
You mean you that midget thing ain't got no starter ???-----:playful:
Keoke, it ain't got no remote starter, nor a button on the relay, either.
PEP BOY's ,Riley's Etc:sell em remotes CHEEP,Steve-:highly_amused:
They are just a heavy duty switch encased in rubber which you can hold in your hand and have 4' insulate leads with insulated Aligator clips on the ends of the leads.
You just clip one lead to the normally excited connection on the starter solenoid and the other to a hot 12V source in the car. Now whenever you press the switch she gonna turn over.
I just roll the car via the right-front tire, and with the multiplication of the final drive, I have very good resolution of the valve moving to the top of its dwell. But I suspect we all have our way to do things, and we're quite set in them too!
My experience is the most accurate valve setting is doing this way. The fomula EOIC
Is still the best for me to get the valves adjusted when they are in the correct position. Howevet, this doesn't apply to radical cams.
A balloon is an accurate way of finding TDC on a given cylinder. I glued a pressure hose into a spark plug body and fastened a finger from a latex glove onto the end with a rubber band. (Sorry no pix)
When the balloon stops inflating and begins to deflate, you can determine TDC. It also helps to have a timing disc on the distributor:
J BJ8 Radiator Fan Austin Healey 12
S Painting a BJ8 Radiator - any advice? Austin Healey 17
wangdango BJ8 lower radiator hose! Austin Healey 2
wangdango Home-made ducting for BJ8 radiator? Austin Healey 11
C For Sale 67 BJ8 radiator- Austin Healey Classifieds 1
L BJ8 radiator cap Austin Healey 6
Marvin Gruber BJ8 Radiator deflectors, what color? Austin Healey 1
AUSMHLY Radiator cap for 64 BJ8 Austin Healey 10
B BJ8 Radiator Hoses Austin Healey 4
C AH BJ8 Radiator Replacement Austin Healey 3
BoyRacer Wanted BJ8 engine block - Wanted Austin Healey Classifieds 5
S Wanted *** wanted: front right frame section for 1967 BJ8 3000 *** Austin Healey Classifieds 8
J BJ8 Choke Cable - Plastic Covers Austin Healey 5
AUSMHLY BJ8 1st into 2nd Austin Healey 0
Mickey Richaud For Sale 1965 AH BJ8 Phase 1 Austin Healey Classifieds 1
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 12
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1960 BUGEYE BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
