BJ8 inner battery hold down?
wangdango
I am just finishing up installing a trunk liner kit on my BJ8 and trying to make it as correct as possible. I do not see how the inner battery hold down bar is attached to secure the battery in the battery box. Also my car is missing the wood spacer, anyone have the dimensions for fabricating this piece?
THanks
Ed
The battery clamp consists of a small piece of angle and two rods with wing nuts . The rods have hooked ends to go in the side of the battery box (there are tabs with holes in) . The angle bar goes on the front top corner edge of the battery to pull the battery back into and against the wood spacer . The rods angle down at a 45ish angle .
dont forget you need the hard plastic battery tray to fit into the battery supports .
Hopefully this may help re sizing of the battery support wood
It is also shown on the AH Spares web site : BATTERY-SUPPORT-wood-1.aspx with the sizing in metric (33cm x 3cm x 2 cm)
I have just made up one of my own in ash to the imperial sizes above and using 1/4" UNF stainless 4 pronged T nuts pushed into the wood.
According to the Moss catalogue the thinner wood piece was used on BJ8s up to body number 76138, 76139 and up used the thicker piece.
Rick
M BJ8 Inner Body Panel Repair Austin Healey 2
R weight of BJ8 Frame with inner body panels Austin Healey 1
BoyRacer Wanted BJ8 engine block - Wanted Austin Healey Classifieds 5
S Wanted *** wanted: front right frame section for 1967 BJ8 3000 *** Austin Healey Classifieds 8
J BJ8 Choke Cable - Plastic Covers Austin Healey 5
AUSMHLY BJ8 1st into 2nd Austin Healey 0
Mickey Richaud For Sale 1965 AH BJ8 Phase 1 Austin Healey Classifieds 1
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 12
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1960 BUGEYE BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
