Spitfire back to Triumph ownership
Triumph Swede
Greetings to all. I am a former Triumph owner and it looks like soon to be return owner.
I have access to a 1969 Mk III garage find, restored 20ish years ago, stored for the last 15ish years. Sweden uses salt and chemicals on the roads in the winter, and the air can be semi humid year round. I would like to know from other spitfire owners, where to look for rust and corrosion before I invest in this little beastie. I am hoping to work out a rolling restoration with plenty of help from the folks on this site.
Any advice on red flags to look for would be greatly appreciated.
Tack sĂĄ mycket!
dklawson
Your posting suggests you are looking at a Spitfire. Based on my experiences only I suggest that while searching for rust you look at...
The driver and passenger floors
The bottom of the battery box
The sills (front to back)
The "dog leg" at the front of each rear wheel arch
The rear panel where it joins the boot floor
and
The bottom of the doors.
Also check the seams on the bonnet both top side and engine side.
T
Triumph Swede
Thanks Doug, I am indeed looking at a Spitfire.
Those are good paces to look, but I was wondering about anything that might be characteristic to the Spitfire, like the MGB's "crack of doom."
dklawson
Even the crack of doom can be fixed if you don't mind welding. I cannot think of a similar bodywork problem with Spitfires.
Though this is probably more a problem on the later 1500 engine, I would check the crankshaft endfloat. If you find you can pry the front pulley backwards and forwards more than a few thousandths of an inch, you can expect problems with the crank thrust washers. This may be a simple replacement if the situation has not gone on too long and if the thrusts are still in place. If the thrusts have fallen into the pan you will find the crank has a lot of endfloat and this may turn into an expensive repair if you chose to fix the block and crank.
I would also test drive the car and listen carefully for any noises coming from the rear suspension and differential.
If an oil pressure gauge has been fitted, check the pressure when the engine is at a hot idle.
lilifer_13 Spitfire New to BCF - New to Triumph ownership Triumph 10
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
XJtom General TR Triumph items of interest Triumph 2
B TR6 Triumph tr6 coolant leak Triumph 4
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
Gliderman8 General TR Triumph emblem? Triumph 13
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
KVH General Tech Making the Triumph Engine Dolly Triumph 4
P Post-War Other Triumph Herald Engine ID Triumph 2
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
D Forum for Triumph TR6 only FORUM Navigation Questions 2
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
