Cgantner5150
Update:
Got the rest of the front body work off today. Pressure washed the front end and got the 60 years of gunk off. Either the shock or the jack system was leaking on the right side. Man was it thick and caked on. Also finally located the frame plate and a plate on the engine. Body is coming off next to ease the frame mods. The engine appears to be painted gold. Was this original?
Located the hand crank and tried to spin the engine. No go. Removed the spark plugs and sprayed some penetrant and oil in the cylinders. Sprayed down the valve train and tapped them loose. Going to let it sit overnight and give it another try. Going to pull it after we remove the body anyway, just want to see if I can free it up.
