Deleted member 10059
austin healey " E " brakes
After installing new rear brakes on my 65 BJ8 the E brake will not hold on a grade, the handle will come completly off the teeth, whats strange is the brake works just fine in a flat surface,2 or 3 clicks and its tight, the cable is ok, no frayd wires,no busted brackets,etc.even tighting the ajuster way tight gives little or no results, any thoughts out there?Mikkus.
