TR2/3/3A Another Carb question.
DavidApp
I have just rebuilt the carbs for the TR3B I am brining back to life.
I got the carb kit from TRF and followed the directions on the cork jet seals soaking them in oil. Left them over night in a dish of oil.
Polished the choke jets and reassembled the carbs. The choke jets move nicely and the jets are centered. The jet centering nuts are tight.
Fired the TR3B up and ran it for a few minutes. This highlighted a hole in the exhaust pipe just below the manifold. Then I noticed that both carbs are leaking at the bottom of the jets.
Did I mess up the cork seals? Are the "O" ring seals better and would Hardware "O" rings work?
David
Graham H
I would think it unlikely they would leak unless they went together wrong ? have you looked at the float levels, with the dashpots and pistons out the fuel level should be below the tops of the main jets.
I don't know about using O rings instead of cork seals sorry can't help.
Graham
ckeithjordan
David,
See Tom Bryant’s March 1 post here:
sp53
Hi David perhaps the brass cup for the cork is upside-down, the cup needs to cradle the cork to expand for the seal. I have also seen the barrels the cork sits inside have cuts inside from the brass cup and leak that way. The rubber O ring is supposed to last longer and maybe they do, but the cork should work for a while. I have cork in mine.
steve
DavidApp
Hello Steve.
I was very careful to get the brass washer the correct way around. Flat side to the spring and cupped side to the cork seal.
Reading Tom Bryants posts he is using/suggesting PTFE "O" rings and Nitrile (Buna-N) o-rings for the top gland nut.
I presume the top gland nut is the jet centering nut with the larger cork washer.
He also mentioned the using anaerobic sealant on the washer between the Jet bearing and sealing nut.
David
sp53
I do not know about any of those options. I have found that the inside of barrel where the cork sits becomes scared by the spring and the cups rubbing and leaks there. Gas typically dissolves most glues. Perhaps give Joe the carb guy a call. He is gruff but cool.
steve
CJD
Hey David,
You may have fallen for the same thing I did. The latest carb kits are providing an extra thick cork washer for the jet assembly (the large cork one compressed by the very large nut at the bottom of the carb that is used to center the jet assembly). The seal is so thick that I only tightened the big nut until it felt rather tight...and then stopped. It seemed right, but I kept getting a leak. I pulled the jets 3 or 4 times, reinstalling with the big nut firmly.
Well, I finally realized that the big nut has to fully compress the cork and continue to tighten until the nut hits metal to metal. With the old, thin, gaskets this was obvious. But it isn't so obvious with the thick gaskets. The jet nut must seat metal to metal to lock the jet into place. Of course the usual "centering" of the jet precautions apply.
DavidApp
Thank you John
So the "O" ring idea may be better under the big nut.
Those cork seals were very thick.
David
CJD
Yes, so thick that you tighten to a point that "seems" right, but it isn't. Keep going until you feel the solid contact of metal to metal.
DavidApp
Thank you John.
I will try that first. Tightening the large nut.
I e mailed Joe in NY and he said t call him on Monday.
David
Donald1107
Speaking of “another carb question,” I have this problem. Gasoline flows out of the rear SU carb float bowl overflow pipe. Why is that and what fixes it? I assume the shutoff valve is not closing tightly. The carbs were totally rebuilt just this past spring.
Graham H
The first thing to do is take the top off the float chamber and make sure the float is floating, it may have a hole and has filled up with petrol. Next check the float height adjustment is correct then blow out the needle valve in case there is dirt stoping it from sealing.
Graham
CJD
The causes for float overflow would be dirt in the float valve, a float with a pinhole that does not float anymore, a float set too high, or to much fuel pressure. American cars use 6 psi to the carbs, but British cars only need 3 psi. Any more and the pressure can overpower the float valve. Most of these, with the exception of high fuel pressure, would only affect one of the two carbs.
Donald1107
It is only affecting one carb; the rear one. And it has a replacement TR3 fuel pump, virtually identical to the original. The carbs were newly rebuilt and professionally tuned, so I doubt the float is punctured. Perhaps dirt in the valve.
thank you all.
DavidApp
Sometimes new parts can be defective.
Check the float is floating and clean the needle valve. There are solid floats available now which gets away from the brass float springing a leak.
I have a filter mounted before the fuel pump. A filter between the pump and carbs would help trap any crud in the system.
David
DavidApp
Hello Graham
Not yet.
I have been distracted by a number of other issues on this car. As parts come in I am getting them sorted out.
The fuel line was cobbled together from 3 pieces of solid line 4 pieces of rubber hose and an electric pump that did not work. A roll of 5/16" Copper Nickle line arrived yesterday. It is a major PITA t fit the line working under the car.
The exhaust had a large hole in it by the manifold and the rear brake lines ran over the bump stops showing evidence of being repeatedly hit as the axle tit the stops.
I did speak to Joe C and he is sending new cork seal.
David
Graham H
Isn't it great to find things done wrong by someone in the past who shouldn't have touched it and really only made it worse than it was.
Graham
DavidApp
Having got the fuel line connected I can pump gas to the carbs.
I did manage to get a 1/2 flat n both large nuts. That seemed to stop the leak.
Today I checked both carbs again and operated the coke jets by hand and the rear one drips gas as I lower the jet. I presume that indicates tha cork seals are bad?
I did polish the jet spindles before reassembly.
Also worth noting is the fact the rear carb choke had been disconnected before I got this car. Maybe it has a history of the rear jet leaking.
David
miranda another carb question Austin Healey 3
martyc Another silly Carb Question [piston spring?!?!?!] MG 3
L another carb problem? MG 14
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
AngliaGT ANOTHER TR6,& an MGB Spotted 0
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
