MGB Air filter
Platinum
Been running the MG with just the air horns, finally got one of the Red Line K&N knock-offs. Not a lot of clearance at the bottom edge though. Likely will swap it out for the screen style individual covers. Or add another shim under the left motor mount. Don't laugh at the Rube Goldberg throttle linkage arrangement! It's worked for decades.
I use the short K&N. It has a single center fastener.
Mum about the linkage.
Yep. The K&N's work on the Elans, but have the same clearance issue on the MG. Just want to keep "the big chunks" from being ingested with the B. As posted, I'll likely go with the individual trumpet covers for that.
That manifold was a home-brew using the spec's for the inlet in the "Special Tuning Manual" back in the mid-seventies when we couldn't get that stuff "over here." I never did make up the braces to the motor mounts, seemed excess to requirement as the street engines it went on weren't pressed into racing conditions.
On a '78 with brake booster space is limited. I've used this one from EMPI for years....
With velocity stacks? This is a '65, no extra booster or suchlike. And your intake manifold looks to be a shorter, tighter radius too.
No velocity stacks, although I've been considering putting stub stacks inside the filter.
Yes, it is the short manifold. the longer one used on the earlier cars won't work on the RB cars with the booster.
As I have written before….you do not fit a weber without stacks!
Or really, any side draft carb. SU's have a short, tapered ram effect "horn" built in to the standard air filter canisters. Short bolt-on trumpets are available.
The Zed-S units were post-emission control and have a poor induction system to start with, so intake flow was the least of the engineering concerns. :devilgrin:
Do that. Anything to "smooth out" airflow going into the throats helps efficiency.
John Passini's book is a great guide: Volume 2: Tuning Weber Carbs
Volume 1 is theory stuff, second one is more practical for getting on with running.
That's th' one. I've both volumes here, just haven't put my finger on 'em.
The Haynes book is here, too. But it isn't nearly as helpful as Passini's. Just "pretty pictures". 😉
Mine are on the shelf in carb section.
You are sooo organized, Larry!
Mine could just as likely be on a shelf between books on Thai cooking and "The Complete Works of Shakespeare."
No tellin' at this point. 🤷
I took all car books out of wife's library so she would have more room. I have books on different drivers and different cars and club magazines on a shelf in a side room. Built a 4' wide , 8' tall bookcase in garage with six shelves and that is full of manuals. Mostly Jag, Rover, Triumph and mixed LBCs with last 2 bottom shelves 1939- 1989. Flat rate manuals from 1939- 1984 are on the desk. The manuals are the only things I can find without searching drawers, cabinets or crawling around on the floor finding what I dropped.
My car books are mostly in one area of the bookshelves but some seem to have 'migrated' to places unknown. Recently found a couple Lotus books in 'Her Area' among the artists tomes. Not sure just why or how they got there. :unsure:
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
F TR4/4A Replacement air filter for SU HS6 Triumph 6
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
E MGB Oiling foam air filter MG 3
M Cooper's Air Filter on H1 Carbs Spridgets 5
tahoe healey Cooper decal on air filter Austin Healey 2
tahoe healey Original Air Filter Maintenance Austin Healey 4
D TR2/3/3A Air filter Triumph 11
sim air filter box for a DCOE 40 Spridgets 3
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
G Brake Booster Replacement Air Filter Austin Healey 4
G TR6 TR6 air filter element replacements for stock housing Triumph 3
Patrick67BJ8 Denis Welch Air Filter for BJ8 Austin Healey 22
J Air filter help Austin Healey 0
J AC air filter tricks and maintenance Other British Cars 0
fpstude TR4/4A Air Filter Soaked With Gasoline - TR4A Triumph 9
W Air Filter Removal Austin Healey 9
G TR2/3/3A paper air filter for tr3 Triumph 1
D MGB mgb air filter MG 2
davidb AH oiling the air filter Austin Healey 13
M Healey Air Filter Rebuilding Austin Healey 1
B SU Air Filter Mounting Triumph 6
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
W GT6 GT6 air filter Triumph 3
jjbunn Air filter cannister guests Jaguar 6
G Euro carb air filter clearance problems Spridgets 2
Newkie Air Filter Assembly question MG 23
F air filter over ram pipe Spridgets 1
P Air filter securing mod Austin Healey 11
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
N Brake servo air filter Austin Healey 2
D Spitfire Spitfire air filter element Triumph 7
T Air filter options Triumph 3
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
T Metal air filter assembly and/or HS1 carb set Spridgets 0
B Picture of Original Bugeye Air filter Spridgets 3
19_again oil and air filter upgrade options? Triumph 10
S E-Type Air Filter Breather Jaguar 0
tweety foam air filter Spridgets 1
C Su carb air filter Austin Healey 1
Brooklands Air Filter for Stromberg 175's Triumph 3
Stewart Oil for weber air filter MG 4
fmichaels air filter question Spridgets 6
eschneider MGB mgb stromberg re-jet for hi-flow air filter MG 30
Z Air Filter Oils Austin Healey 1
Baz K&N Air filter assbly Spridgets 5
Atrus Air in fuel filter Spridgets 11
Woodie air filter vendor Spridgets 2
Woodie air filter diameter Spridgets 0
