TR6 73 TR6 Distributor question
jerrybny
Hi I'm wondering if anyone who has a 73 TR6 knows the distributor part number. Mine is very hard to read. 1 of the numbers is stamped right on what looks like a weld. I think my number is 41588. Thanks in advanced.
jerrybny
jerrybny
I'm a little confused now. I think my number is 41588 and you responded that I was right but posted 41558. Did you mean 41588?
RomanH
Sorry Jerry,
I mis read the numbers in your original post. I should not have said you got it right.
The number is 41558A. Sometimes the 5 and 8 are hard to distinguish because of the way they are stamped.
Roman
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
A TR6 TR6 Distributor cap issue Triumph 4
smaceng TR6 TR6 distributor advance and retard hook up Triumph 6
I TR6 Correct way to tighten distributor on TR6? Triumph 1
I TR6 Distributor help on TR6 Triumph 5
G TR6 1974 TR6 distributor advance spring specs Triumph 6
B TR6 'Cutting-down' a TR6 distributor ? Triumph 26
W TR6 Tr6 1974 Distributor Triumph 7
veale001 TR6 TR6 Distributor problem........................... Triumph 39
I TR6 TR6 distributor suggestions? Triumph 12
J TR6 TR6 distributor info needed... Triumph 8
jerrybny TR6 69 TR6 Distributor Triumph 1
I TR6 69 TR6 distributor/vacuum advance/retard help Triumph 4
T TR6 TR6 distributor removal - tips on tach drive Cable Triumph 5
N TR6 Need TR6 distributor advance weight spring Triumph 3
G TR6 tr6 distributor Triumph 13
tr6web TR6 Tachometer and distributor problem - '72 TR6 Triumph 6
Hawk813 TR6 TR6 Brakes Triumph 2
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
