    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
67 Midget Clutch travel.. one more time...
Gunner
I'm sure this has been well discussed... but I'm still unsure about my clutch... before I pull my engine to check my clutch/throwout bearing, etc...
I jacked up my midget, disconnected my slave cylinder and clamped a pair of vice grips to the clutch rod... can anyone tell me how much pressure it should take to disengage the clutch? It seems like I was having to apply an inordinate amount of pressure to move the clutch rod even 1/2 inch... It could be that my clutch plate is frozen to my flywheel...
Thanks for all your help.. /ubbthreads/images/graemlins/driving.gif
Sid,
I have never been able to manual move any clutch. If you can move those clutch fingers by hand you have a problem. That is why there is hydraulic pressure and before hydraulic pressure there was linkage and levers. If you clutch plate is frozen to the flywheel your transmission will not disconnect from the engine.
That's exactly what I was needing to hear, Wolfman.. Thanks.
I may just pull that engine anyway now that I have the engine accessories off...
Who sells the ball bearing throw out bearings?
For example, 1000psi hydraulic pressure is about 450 lb at the fork lever & 1500psi is 650lb. That's a lot more force than you could pull with a vice grips.
I would stay with the carbon throwout bearing. They are made to last a good long time with normal usage. I'm not convinced that the ball bearing type would be an improvement.
G 79 Midget Clutch issues Spridgets 9
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
B MG midget Clutch slave cylinder Spridgets 5
M General MG Midget clutch bleed - engine out MG 3
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
S General Tech MIdget Clutch- Totally stumped. MG 2
S MIdget Clutch- Totally stumped. Spridgets 6
R 1500 midget clutch inspection? Spridgets 3
G 79 midget 1500 clutch? Spridgets 5
E Clutch issue with 1973 Midget, moved from MG board Spridgets 16
E T-Series 1973 MG Midget, Where to Start with a clutch issue MG 8
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
P weird thing with midget clutch pedal Spridgets 3
P clutch adjustment on 79 midget? Spridgets 6
Steve P. Midget [1500] clutch threshold? Spridgets 4
Steve P. Help! '78 Midget clutch & light switch Spridgets 13
R spitfire OD in MG midget, trany & clutch question Spridgets 4
D 79 Clutch Midget 1500 eng. Spridgets 7
G Midget 1500 Water Pump / Fan Clutch Question Spridgets 6
G 1500 Midget Clutch & Transmission Question Spridgets 7
tony barnhill '63 Midget Clutch Spridgets 9
G Midget's Stuck Clutch Woes!!! Spridgets 10
D T-Series 79 Midget clutch MG 15
7 T-Series 1976 midget clutch problems, please help me. MG 17
C T-Series Midget clutch slave where? MG 5
M T-Series 74 Midget Clutch Question MG 2
K T-Series clutch system on a midget MG 9
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 18
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
