1993 Cutlass convertible blowing a fuse
wkilleffer
Hey gang, long time no posts. Here's a non-Brit problem that's got me stumped.
A couple of months ago, I bought a 1993 Oldsmobile Cutlass convertible. I know very little about its past. When I bought it, someone had installed a dash-mounted DVD player and an Infinity 300watt amp and sub in the trunk. Kinda neat and sounded ok, but it all seemed like a theft target, so I got to work removing it and installing a less theft prone factory radio so I could regain use of the steering wheel-mounted controls.
This process ended up pretty involved, as there was quite a bit of dodgy wiring up under the dash. I got all that out and got the wires patched together properly. I also installed new speakers up front. For awhile, everything seemed to be working well, but then it started blowing a 15amp fuse labeled ELEC in the fuse panel under the glovebox. This fuse is always hot, and controls the radio, climate control, and some kind of door switch. This car is equipped with Electronic Climate Control.
At first, it seemed rather random, so I went back into the dash looking for potential short circuit locations. I found one and insulated it. Everything worked well for a couple of days, and then the fuse blows again. I got back into the dash, and all seemed well. So I was baffled.
Now, after putting everything back together, the fuse blows again. But I've noticed something odd. It doesn't blow as long as the car's doors are closed.
This car is equipped with those odd pillar-mounted door handles that one pulls downward to open the door. To further complicate things, just to check an idea, I plugged a new fuse in and started the car. All was well until I opened the driver's side door, then the fuse blew.
I tried it again, and watched the display on the radio as I opened the door. As soon as I pulled the handle down, the radio display dimmed and then went out. The fuse had blown.
This is an odd situation and I'm not sure where to go from here. I suppose open the door up, but what to look for? Any suggestions would be appreciated.
Thank you,
-Bill
Banjo
Take the inner door panel off. incorporated into the wiring in the door for the power locks and such is a wire that runs to the door latch switch from the 15A Elec fuse. It's orange. there is likely a second wire going to the switch as well as a return signal to the passive restraint/ door lock system, but I haven't been able to find it in a diagram. a visual inspection should be able to spot it.When you pull the handle for the door latch, it closes the switch and shorts out that orange wire. I'm betting the other wire is grounded, but it shouldn't be.
The short cut would be to cut the orange wire, but then I bet your power locks won't work. (That's how it knows if a door is open or closed)
Suspect places to look for problems are where the wires go across the door jamb. Pull back the boot to inspect wires. the flex there every time the door is opened, and over time tend to break. also if any of the wires run under the carpet, look for water intrusion. Also make sure speakers being put in the doors diden't put screws into any wires, or pinch them against the metal door frame.
wkilleffer
wkilleffer
Ok, my dad came over, and after some examination, we found a broken wire inside the driver's door. Put it back together, and the illuminated keyhole near the door handle started working. A funny feature if ever there was one, especially since it's only on the driver's side.
The good thing is that the blown fuses appear to be a thing of the past. But now, the Electronic Climate Control is doing what looks like some kind of crazy diagnostic mode that I can get to stop. The usual tricks don't work. But having one less really bad problem is a plus :smile:
wkilleffer
wkilleffer
Hey Banjo,
You must have replied just as I was getting my reply together. Thank you for your suggestions.
Any idea of what to do about the climate control issue?
Banjo
Not sure there. Check inputs and make sure all is good. likley something had gone screwy inside. I'll look a bit later tonight when I have time to dig.
Is it a Cutlass calais, or Supreme (I suspect it's a Supreme)... any other badge like "S" or whatnot?
AngliaGT
'93 Cutlass convertible?That would be a non-factory car,-
wouldn't it?
- Doug
Banjo
Diagrams I looked up offer a convert' in the options.
S 1993 dodge Dakota shifter Other Cars 9
T 1993 xj v12 red hot catalytic converter Jaguar 6
P For Sale 38k Mile 1993 Bentley Turbo R For Sale on Bring a Trailer Other British Classifieds 0
J For Sale 1959 Morris Minor Convertible Other British Classifieds 3
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
Sarastro TR4/4A Convertible top installation problem Triumph 12
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Overdrive45 Convertible Top Cover Fit Austin Healey 6
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
JPSmit Jag XJS convertible Spotted 0
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
P For Sale 1958 sunbeam rapier convertible and hardtop (coastside/pescadero) Other British Classifieds 0
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
N MGB Convertible Top Frames MG 7
P Hillman Minx Convertible Spotted 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
TomMull Convertible hood frame Other British Cars 3
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
B 1965 herald convertible Triumph Classifieds 1
T Austin A-90 Atlantic convertible parts Other British Classifieds 1
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 1
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 0
S For Sale Triumph TR-3 Convertible Top Bows Triumph Classifieds 1
AngliaGT 1969 Impala Convertible Spotted 0
S 2019 Convertible Noise_Squeak British Motor Corp 4
C Austin A40 Sport Convertible? Help! Other British Cars 3
M TR4/4A Convertible rack. Triumph 1
charleyf For Sale TR4 convertible frame cover Triumph Classifieds 0
RAC68 Shim Adjustment of BJ8 Convertible Frame Austin Healey 5
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
LarryK General TR 1962 Herald Convertible Triumph 10
TulsaFred Convertible Top Fitting problems Spridgets 29
AngliaGT Chrysler 300 Convertible Spotted 1
Griz Convertible top installation Austin Healey 6
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
J TR4/4A Too hot to drive a convertible Triumph 14
TRMark Austin Convertible at Auction Other British Cars 10
Griz Convertible top installation Austin Healey 8
aero3113 100-4 Convertible Top Austin Healey 9
RAC68 Cuts in BJ8 Convertible Top Austin Healey 5
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
RAC68 Repair Traditional Cuts in BJ8 Convertible Top Austin Healey 18
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
