1973 RWA MG Midget project car
Whitephrog
Need to sell a 1973 RWA MG Midget project car complete with 1275cc engine and ribbed case transmission. I obtained the car as a donor with a Bugeye tub. Car is 95% plus complete. I had decided to restore it but have changed my mind as my primary interest is restoring Bugeyes.
Floor pans are rusted out. Inner and outer rocker panels need replacing. There is rust thru in the usual place behind the rear wheel arches. Comes with a pair of new outer rocker panels. Asking $750.
Car is located in East Tennessee. VIN # GAN5UD137559. Lot's of photos available.
Ray Evans rnevans@bellsouth.net
GB1
welcome whitephrog, At least it has RWA, sorry I can't help, I (probably like you) like the RWA's
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
S Stag 1973 Triumph Stag Triumph 2
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R TR6 1973 Final drive issues Triumph 5
K 1973 MGB for sale MG Classifieds 0
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
Boink 1973 Marcos MINI Spotted 1
J 1973 2500M ignition issue TVR 8
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 TR window regulator Triumph 2
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
