1500 engine rebuild
maddy
I'm going to pull the 79' 1500 engine soon and need good instructions on rebuilding it. Haynes doesn't quite cut it. I have rebuilt a couple of engines years back, Chevy and Ford, but never an MG.
Any suggestions would be appreciated.
JPSmit
what are you looking for specifically? It's an easy rebuild as it is a simple engine.
Thrust bearing are the PITA of the 1500's
take lots of pictures and keep everything in order but we can certainly talk you through.
Someone else will come along and tell you what gaskets to get.
for me the hardest part was reinstalling the timing chain, mostly because I didn't take it apart.
RichBall
This is not so much a guild as just some good information on the 1500
https://www.totallytriumph.net/spitfire/engine_building.shtml
Spitbits in California is a good source for 1500 parts that many of the other suppliers don't carry. I used them when I needed some large manifold hold down ears. Good price and fast shipping.
https://www.spitbits.com/
Are you still running the ZS carb? I have a couple good references for tuning and rebuilding if you’re interested.
Rich Ball
'76 Midget
Everett, WA
Morris
One thing I did not do when I rebuilt my 1500 that I regret was replace the stock cam with an early Spit cam. The stock cam on a 1500 is installed without bearings. I am told, the early Spit cam bearings will fit right into the stock journals in the 1500 block. Spitbits has a great deal on the early spit cam:
https://store.digitaloutlook.com/Store/showdetl.cfm?&DID=63&Product_ID=18993&CATID=154
You will also need to get these bearings:
If you do not want to go this route, you may also consider having your machine shop bore your block for custom bearings. I have no idea how much this will cost. And I would not recommend you have just any machine shop attempt this procedure.
dklawson
You've already gotten a lot of good advice above. The only thing I would like to add is that you may want to parallel this post in the Triumph section of this board. As was suggested via the posts above, the Midget 1500 is a Triumph engine and you're likely to get lots of good advice from those in the Triumph forum. In particular you'll find information on pinning those thrust washers in place.
M
maddy
I've read that 77 MGB rod bearings modified can help this engine. Can anyone shed some light on this for me?
Thanks.
jlaird
On the street I expect stock is sufficiant.
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
R 1500 engine rebuild hints Spridgets 33
R 1500 engine rebuild, suggestions for improvements? Spridgets 46
pjsmetana 1500 engine rebuild - part 1; planning Triumph 25
M General MG MG 1500 engine 4-91 or 4-110 MG 3
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
regularman Crankshaft pulley nut for 1500 engine Triumph 5
T 76 midget 1500 engine crud Spridgets 4
R dual springs for 1500 engine rocker arm upgrade? Spridgets 3
JPSmit 1st time - 1500 engine on ebay. Spridgets 13
F Spitfire 1500 Spitfire Engine Noise Triumph 14
R rebuilt or used 1500 engine for sale? Spridgets 3
Steve P. 948 distributor on 1500 engine? Spridgets 4
Steve P. MGA Metropolitan 1500 engine same as MGA??? MG 4
pjsmetana Auxiliary Oil Feed to Rockershaft on 1500 engine Triumph 4
Scott_Hower Bell Header for 1500 engine... Spridgets 12
G Size of socket to turn over 1500 engine by hand Spridgets 9
G Socket size to turn over 1500 engine by hand Triumph 4
6773 pic 1500 engine bay Spridgets 5
B Polishing and Porting a 1500 engine Triumph 9
B small wooden gaskets for 1500 engine. Triumph 9
R engine hiss, PVC on 1500 midget Spridgets 20
C 1500 to 1275 engine conversion Spridgets 21
M Spitfire spitfire 1500 vs MG Midget engine Triumph 8
D 1500 engine vibrates Spridgets 13
JPSmit 1500 Owners - Engine Assembly Help Spridgets 12
R 25D distributor on 1500 engine? wrong distributor? Spridgets 2
aeronca65t 1500 Midget engine/trans/etc Spridgets 0
B Dipstick location on 1500 engine?? Spridgets 11
Michael Oritt Rear crankshaft seal for 1500 engine? MG 5
C Looking for a 1500 engine Triumph 11
A 1500 Engine Weight Spridgets 10
S advice on minor engine upgrade to 1500 Spridgets 9
D MGA Wanted: MGA 1500 or 1600 engine or block MG 4
8 1500 ENGINE Triumph 1
8 1500 ENGINE NOISE Triumph 6
J another 1500 engine question Spridgets 4
J 1500 engine question Spridgets 4
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
