73 Midget rocker panel end caps and door handle gaskets advise
fordmstr
fordmstr
Is there a right way to install the front and rear rocker panel end caps? The ones I've purchased have 1 hole on the flat side that butts up against the body sheet metal. Do you just install with one screw so they can be removed later to access inside the rocker panel or is it best to weld them into the body sheet metal?
Another question is about the door handle gaskets. The ones that came from Moss in a body rubber kit are almost paper thin, looking around saw some new old stock from England wondering if they look like a better seal. Not messing with the trunk handle seal, it seems in good shape and made of rubber.
Bayless
I had to replace 2 on my 67. The others were welded in so I did the same. I did shoot both sills inside with a lot of Rustoleum rusty metal primer then paint first though.
fordmstr
fordmstr
Thanks Bayless, wasn't sure what to do but welding does sound like the strongest way to attach them. I painted both sides of the inner sills after welding in with Por 15 and covered with black enamel spray can paint, also both insides of the rocker panels. Had to mark and grind off about a hundred spots before welding but easier than grinding down the welds were.
Noticed your Personal Page link, must have spent 3 hours there following the progress on your AH Sprite project. Looks like all your hard work is paying off, it looks show car quality now.
My wife had a 69 Bug when we first got married, my first paint job was on it. Changing it from white to similar color of blue yours was. Rented a compressor and spray gun at the time, prepped and painted it in my parents garage. Not knowing anything, mixed the paint and thinner per the recommendations 50, 50. Big mistake paint came out like cotton candy. Should have thinned it down more, sure it would have helped. But at the time I was young and dumb. Looked great if it was raining or wet but close up it sucked.
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 12
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
